Old 11-25-2012, 11:05 AM   #1
Replacing a Simplecomfot Tstat with Honeywell wiring
I am replacing a SimpleComfort 2200 with a Honeywell RTH3100C and need help with the wiring.
Here is a picture of the SimpleComfort unit:
And here is the connector for the Honeywell:
Can anyone help with the wiring? It's cold out baby!
Thanks!
Tom
Tabman is offline   Reply With Quote
Old 11-25-2012, 11:16 AM   #2
I'm Your Huckleberry
R-24 volts (red wire)
O-reversing valve for heat pump (brown wire)
C-common (blue)
G-fan (green wire)
Y1-Cool (yellow wire, will go to Y on new stat)
All the above will be like for like.
W2-heat (will go to aux on new stat)
Turn the breaker to the furnace off first as you stand the chance of blowing a fuse, transformer or possibly the board.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 11-25-2012, 05:46 PM   #3
Thanks Doc!
It's working like a champ.
Tom
Problem: Replacing Honeywell T6960 with Honeywell TB6575 RT2020 HVAC 1 07-21-2012 03:05 AM
Replacing a Carrier thermostat with a Honeywell thermostat Fred Lambrerth HVAC 2 07-11-2012 06:02 PM
Replacing Honeywell T822D-1255 Dee001 HVAC 11 11-16-2011 10:45 AM
Replacing old Honeywell thermostat with new Honeywell thermostat optimizer HVAC 13 04-20-2011 07:22 PM
Trane Heat Pump tstat replacement with Honeywell prog - wiring question sep23 HVAC 2 10-20-2006 10:10 PM
