Replacing Return Air Duct Without Using Firdown - HVAC - DIY Chatroom Home Improvement Forum
Old 11-06-2011, 09:40 AM   #1
Replacing return air duct without using firdown
I am remodeling our bathroom and I want to remove all firdowns. There is a return air plenum built into the firdown. I was thinking of using 3.25x10 inch rectangular duct to go inside the wall however this will require removing the upper plate in the wall to allow the duct to enter the attic. I am concerned about the effect of this on wall integrity.Does anyone have suggestions or best practices regarding this?
Onenotchover is offline   Reply With Quote
Old 11-06-2011, 10:05 AM   #2
An old Tradesmen
Rewards Points: 6,108
It can be done, should be plated afterwards. But, how big is the current plenum? Are you sure the little 3 1/4 X10 will be enough.
Old 11-06-2011, 10:37 AM   #3
Plenum size
The return duct to the furnace is 14". It was supporting (3) 8 inch ducts. One for the living room, one for a bedroom and one for an office. I am replacing them with (3) 3.25x10 rectangular duct with 7 inch caps that will connect to a duct box to tie all to the 14 inch duct.
Old 11-06-2011, 03:46 PM   #4
An old Tradesmen
Hopefully your A/C if you have it is only 1 ton, cause your 3 - 3 1/4X10 will only support that. And you furnace is only a 40,000 BTU input 80% efficient furnace.
New return duct size questions blackhemi HVAC 1 06-26-2011 07:50 AM
Return Air Duct Work d.osborne HVAC 1 12-29-2010 05:25 PM
holes in return duct -- why? ductnovice HVAC 6 12-12-2010 06:33 PM
Moving Return Vent Upstairs Rowhousefix HVAC 0 08-11-2010 03:39 PM
Heater Return duct - Moved to HVAC forum backpacker2 HVAC 1 05-16-2007 12:30 PM
