Old 05-28-2008, 06:45 PM   #1
Default replacing rectangular duct with 6" pipes
Hi,
I currently have an "extended plenum system" with one large rectangular duct (24"x6", 25' long) and 4 6" pipes branching off. I want to replace the rectangular duct and just go with flexible 6" pipes the whole way because the rectangular duct is large and taking up valuable headroom whereas it will be possible to more or less hide the pipes. Will this result in significant reduction in airflow? Is there a rule of thumb for how long you can go with a 6" pipe?
Thanks!
Peso
peso is offline   Reply With Quote
Old 05-28-2008, 06:51 PM   #2
Actually, they don't have to be flexible, they can be regular metal pipes if that's better. They would just need a couple 45 degree elbows.
Old 05-31-2008, 11:36 AM   #3
oops, did I do that!
Not a good idea to remove the branch duct 24x6.
Yes it will effect air flow.
15ft is normaly the max for flex duct.
In order to achieve the same velocity and volume, you would have to start out with a larger diameter duct...more loss of headroom.
Again...not a good idea.
8 Ball is offline   Reply With Quote
Old 06-01-2008, 10:05 AM   #4
coolmen's Avatar
removeing the main trunk and bring all pipes to the plenum above the furnace is a bad idea. we call this a octapuss design, usally designed by some HACK. depending on how long the 6" runs are you will have uneven flow. get a pro to come in to see how best to fix your problem.
coolmen is offline   Reply With Quote
Old 06-05-2008, 10:43 PM   #5
mmmmmm
ro9beam2002 is offline   Reply With Quote
More On This Topic
Room additions are an exciting remodeling project. It's nice to anticipate the enjoyment of extra space in your home. But you want the room to be comfortable year round for maximum enjoyment. There are several ways and means to accomplish this. Read More »
I'm Melina and welcome to Expert Village. Today, I am going to show you how to make screen print design on a t-shirt. The first things that you are going to need a regular piece of paper, where you?re going to draw a design. You?re going to need waxy... Read More »
Hi, I'm Marti on behalf of expertvillage.com and we are going to talk about how to clean your iron. Actually if you rub your paste on there and let it sit for 30 seconds to a minute and the elbow grease nominal. Then whip off your iron now you have a... Read More »
I'm Cathi Pare, with water resources in Santa Barbara speaking to you today with expertvillage.com and we are actually looking at drip systems right now and maintenance you can do as a home owner. One of the first things you are going to do before your... Read More »
The Polaris all-terrain vehicle, or ATV, is a popular brand of four-wheeler. This recreational vehicle allows riders to go off-road to enjoy rougher terrain. The maintenance for these vehicles is very important, though, as riders can find themselves in... Read More »
Condensation in Wall: Can I Seal a Dryer Duct With Caulk? xquercus HVAC 5 07-01-2007 04:33 PM
1000-1400cfm...duct sizing Swordfish215 HVAC 1 01-15-2007 05:22 PM
Drain Pipes, Walls and Studs mattaparity Plumbing 1 11-02-2006 09:44 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
