Old 09-09-2009, 10:32 PM   #1
Replacing Packaged Air condtioner with heat pump in mobile home
I would like to replace a packaged air conditioner with a packaged heat pump for a mobile home. It has a gas furnace that is very expensive to heat. The model of existing ac is Nordyne P3RA-036K. That is a 3 ton unit. I wonder if that is to much for this old trailer. 12x70.
75harley is offline   Reply With Quote
Old 09-09-2009, 10:36 PM   #2
GC/Master Plumber/Mech
.........and where do you live?
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 09-09-2009, 10:48 PM   #3
It is for my daughters trailer in Elizabeth City, NC. Last winter it cost $100 a week to heat that trailer. I was hopeing to replace the gas unit and run a heat pump.
Old 09-09-2009, 11:17 PM   #4
hvaclover's Avatar
Your are limited to the amount of heat produced by the ac out, in this case 36,000 btu. But as the temp drops the so des the heating capacity of the HP.
You'll need electric heat strips added to the pkg unit to make up the difference.
You electric rates are cheaper than your gas rate aren't they?
Just slow, not stupid.
hvaclover is offline   Reply With Quote
Old 09-09-2009, 11:20 PM   #5
A heat pump alone is not going to solve your problem. As it gets pretty darn cold there in the winter and the effenicy of a HP will drop as it gets colder. You will need either an electric or gas as second stage heat.
Where others won't tell you I will that you need to keep in mind it's a trailer. These type of homes can be a mess to heat and costly.
Old 09-09-2009, 11:23 PM   #6
It seems that electric is cheaper. Most homes in this area are heated and cooled with heat pumps. Thats why I was thinking about removing the gas furnace and replacing it with a heat pump. The outside AC unit still works fine. It is a 10 seer, so maybe a new model would also help for the summer as well.
Old 09-10-2009, 12:05 AM   #7
What about just replacing the gas furnace with an electric furnace and leave the outside AC unit alone?
Old 09-10-2009, 12:19 AM   #8
hvaclover's Avatar
You can't do that with out hacking up the package unit.
Old 09-10-2009, 06:05 AM   #9
An old Tradesmen
He can if he has a down flow gas furnace, and just a packaged A/C.
100 bucks a week?
Small LP tank?
To install a packaged heat pump. You will also need to see if the electric service can handle the strip heat.
3 tons may be a bit large for that MH.
Also, what temp does your daughter have her thermostat set for.
Old 09-10-2009, 07:36 AM   #10
hvaclover's Avatar
I thought he said GAS package ac. I didn't get that he had a separate furnace
I looked up the mod #: it's straight cool. My bad!
Old 09-10-2009, 07:43 AM   #11
hvaclover's Avatar
100 bucks a week?
Small LP tank?
Not in the Carolinas and not for a mobile home...especially if it's an older one.
Old 09-10-2009, 07:44 AM   #12
hvaclover's Avatar
You can pull the old furnace and in stall a Electric heat air handler.
Old 09-10-2009, 12:30 PM   #13
It is a separate down flow gas furnace and Package AC unit outside. I have 2 options, replace gas furnace with electric or replace both gas furnace and AC unit with a heat pump. The electric furnace would be a cheaper up front cost. She does keep it kinda warm because she has a baby. Another reason why I would like to remove the gas...
Old 09-10-2009, 01:07 PM   #14
An old Tradesmen
What is her electric rate, and what is her LP rate.
While an electric furnace could be cheaper up front. It could cost her more to heat with.
Old 09-10-2009, 03:55 PM   #15
Last winter they used $100 of gas a week. I just dont see a new electric furnace costing more than that. I will make sure all the duct work is in order.
Heat pump ice up signpainter HVAC 9 01-02-2012 10:44 AM
Replacing Heat Pump dec1000 HVAC 10 05-02-2009 07:14 AM
Please answer this question about my Carrier Heat Pump... jifmom HVAC 4 02-20-2009 12:38 PM
Heat pump circuit breaker pbms pinkertonpv HVAC 11 02-18-2009 10:47 AM
heat pump not working kyleGR HVAC 2 05-30-2006 03:35 PM
