Replacing One Furnace With Two New Ones - HVAC - DIY Chatroom Home Improvement Forum
Old 04-17-2010, 12:31 PM   #1
Replacing one furnace with two new ones
We need to replace one of our two forty year old original furnaces in our southern Alberta two floor home. The house is 2400 square feet and both thermostats are set to the same program. We are gradually upgrading the basement and attic insulation. We would ideally like to replace both furnaces with one new high efficiency furnace. We have had one installer advice for it and one advise against it! Any un biased opinions would be welcome!
Suek is offline   Reply With Quote
Old 04-17-2010, 01:16 PM   #2
What were their reasons?
I have heard many people noticing no difference in their utility bills going from low to high efficiency. Ideally I guess you'd be billed for 100(83/95) = 87% of the amount you used to pay.
Old 04-17-2010, 04:01 PM   #3
Thanks for your response. We would of course welcome smaller gas bills but would like lower initial cost of only putting in one new furnace rather than two. One installer felt that the lack of flexibility in the two zones in the house would eventually frustrate us. The one who was happy to change the two for one felt that mechanically adjusting the dampers to the individual levels would work just fine.
Old 04-17-2010, 05:28 PM   #4
Hvac Pro
yuri's Avatar
Rewards Points: 2,266
Two would be better as that is what the house ductwork is designed for. I professionally balance ductwork and doubt if your situation will work well. The ductwork for the whole house would need to be designed for one furnace. The largest high efficiency furnace is 130,000 BTU which may be too small for your house along with the physical fan size. If you want to spend some $$ and get a professional engineer to assess your ductwork size and do a heat loss calculation that is the only way to know for sure. 2 furnaces are better than one as when 1 breaks down you have another one which will at least keep the pipes from freezing.
Old 04-17-2010, 06:43 PM   #5
If one furnace is 10% likely to break down when you need it, there is only a 1% chance that both will break down when you need a furnace.
If two small ones costs less than or equal to one big one and you are concerned about reliability this choice is easy.
Old 04-17-2010, 08:37 PM   #6
An old Tradesmen
Rewards Points: 7,356
Even if you have both thermostats running the same program. Your first floor unit is doing most of the heating.
Heat rises.
So you will find trying to manually balance the duct system a bit harder then you think. To almost impossible.
Have a load calc done. And see what size "Furnaces" you really need.
You should still be using heat. So see how often your first floor unit runs compared to your second floor unit. That will give you an idea of how hard it would be to balance 1 furnace, since your duct is set up for 2 units.
I have heard many people complain about temp problems because they went from 2 furnaces to 1. Never heard anyone complain because they went from 1 furnace to 2.
Old 04-18-2010, 06:41 PM   #7
Originally Posted by yuri View Post
Two would be better as that is what the house ductwork is designed for. The ductwork for the whole house would need to be designed for one furnace.
agreed
PA_DIY'er is offline   Reply With Quote
Old 04-19-2010, 01:22 PM   #8
sktn77a's Avatar
Rewards Points: 392
As a previous poster said, hot air rises, cool air falls. This means that with a single system, you will be adjusting your dampers in the summer to blow more cool air upstairs and adjusting them again in the winter to blow more warm air downstairs. Go with the two systems your house and ductwork were designed for.
sktn77a is offline   Reply With Quote
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
Replacing my furnace... Confused on Diaphragm vs closed... nperkins HVAC 11 12-26-2008 07:15 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
Replacing My Furnace, few simple questions compression HVAC 10 02-03-2007 05:00 PM
