Replacing Old In-wall Electric Heater - HVAC - DIY Chatroom Home Improvement Forum
Old 12-29-2009, 02:55 PM   #1
Replacing old in-wall electric heater
I have a 30-year-old in-wall 1500W electric heater that I'm looking to replace with a new, 1500W heater. Have there been technological advancements in the last 30 years that may save me some money on heating costs? 1500W is 1500W... On full blast it will require the same amount of electricity but will it put out more heat? Does it make sense to replace a working heater?
Thanks!
tomasz.
tomaszp is offline   Reply With Quote
Old 12-29-2009, 05:34 PM   #2
I wouldn't replace an electric heater for no reason. Like you said 1.5 kw is 1.5 kw so the operating cost is the same. That small of output can be had at any hardware store with a fan and thermostat control for $50.
Old 12-29-2009, 05:40 PM   #3
Maybe for safety reasons, assuming the stuff nowadays is safer.
Old 12-29-2009, 05:46 PM   #4
that old i would think the newer would probably be running more efficient
Old 12-29-2009, 06:09 PM   #5
Not really. Physics hasn't changed much in thirty years.
jerryh3 is offline   Reply With Quote
Old 12-29-2009, 06:22 PM   #6
I'd maybe look at the wiring, inside & out of the heater
But if it is working I would not rip it out
Heck, some stuff was made better in the past
Old 12-29-2009, 08:10 PM   #7
An old Tradesmen
Rewards Points: 7,328
Might have a more efficient blower motor.
But the heating element will be the same efficiency.
Sometimes, the fins get a lot of dirt in them and become insulated, and the air can't pick up the full heat.
Old 12-29-2009, 08:15 PM   #8
as seen on tv
Rewards Points: 150
You could always buy one of those amish built fire place heaters!! that look like an old tv
qbert is offline   Reply With Quote
Retaining Wall and Muddy Yard rjschwar Landscaping & Lawn Care 10 02-24-2010 12:55 PM
Questions about repairing old wall heater darsunt HVAC 1 02-03-2009 02:49 PM
Electric Baseboard Heater Problem goombie Electrical 9 12-23-2008 12:13 AM
Leaking Rheem 60 gal Electric Hot Water Heater aklkuno1 Plumbing 3 10-22-2008 10:13 PM
Pool timer on an electric water heater...Yes or no? Gusaroo Plumbing 2 09-01-2008 08:13 AM
