Replacing Old Thermostat With Totaline - HVAC - DIY Chatroom Home Improvement Forum
Old 05-14-2010, 02:42 PM   #1
Replacing Old Thermostat with Totaline
I am replacing an old, circular thermostat in our church with a Totaline P374-1700. The thermostat controls only A/C, and we chose Totaline to be reset in the same way as Totaline P374-1800's which had been installed for new A/C's elswhere in the church.
The old thermostat was hooked up to 3 wires, Red, Yellow, and Green. I hooked up the same wires to the indicated terminals on the new Totaline, turned on the power, and nothing happened. The thermostat showed no sign of power or life.
I went to the previously installed P374-1800's (also for A/C only) and found that the 3 wires, and the jumpers, were identical; but the P374-1800's had an additional blue wire, connected to the "C" terminal.
Must I put in 4-wire wiring to the P374-1800, or is there a way it will work with the 3 wires already in place?
40bill40 is offline   Reply With Quote
Old 05-14-2010, 04:26 PM   #2
An old Tradesmen
Rewards Points: 7,384
Need 4 wires.
Tags
3-wire , thermostat , totaline
Replacing Honeywell thermostat with another Honeywell flipz HVAC 4 02-06-2010 04:19 PM
Replacing a thermostat mnwalsh1 Introductions 0 11-08-2009 01:31 PM
Replacing thermostat...................... sktn77a HVAC 6 09-02-2009 10:07 PM
Totaline thermostat trouble shooting Goldwing93 HVAC 3 07-30-2009 10:35 PM
Totaline thermostat to work with two wires evlap HVAC 8 11-15-2008 07:49 PM
