Old 10-03-2007, 10:36 AM   #1
replacing old oil furnace with new propane hi eff.
Ok I been working on this old foreclosed farm house for a while now. It has an OLD oil furnace (HUGE) with ductwork spidered all over the basement. the second story bedrooms only have 1 register in each room.
1. When replacing the furnace should I replace all the ductwork with a more efficient layout?
2. is it better with a 2 story house to have 2 seperate furnaces and central air units for heating and cooling. This is the setup we have in the house we currently live in. granted it is a lot bigger than the farmhosue we are redoing but it is AWESOME for cooling the second floor in the summer
In your opinions what is the best route to go before I start calling contractors and getting estimates
Should I re-use the existing ductwork? does it make sense to put in seperate units for main and second floor?
We are dealing with about an 1850 sq ft 2 story farmhouse. it is getting completely gutted so walls arent in yet and would be fairly easy to run new ductwork.
We are in illinois, fairly cold in the winter hot in the summer
What have I done is offline   Reply With Quote
Old 10-04-2007, 07:02 PM   #2
1. Yes - if you are able to.
2. With it only being 1850 sf then one unit should be fine. I would think that you will be insulating it before the drywall goes up - this will help with both heating and cooling efficiency.
redline is offline   Reply With Quote
Heil Furnace Burner Problem timothyr HVAC 78 01-18-2013 07:49 PM
Replacing My Furnace, few simple questions compression HVAC 10 02-03-2007 06:00 PM
Cozy Propane Furnace Start up Noise NJ Gimo HVAC 7 01-01-2007 11:06 AM
Replacing Old Boiler Type Furnace bobo HVAC 15 10-29-2006 10:45 AM
sooting up of burn box in propane furnace geden HVAC 2 12-04-2005 12:32 PM
