Old 04-14-2011, 09:42 AM   #1
Replacing old Honeywell thermostat with new Honeywell thermostat
Hi,
Not sure if this is something a DIY'er should be attempting to do - I thought it would be more straightforward than it now seem!! Lol...
I live in a condo where we have the old Honeywell thermostat pictured below. I don't know much about our heating / cooling system, but I believe that the condo centrally controls whether the heat or AC is on - and that's really all I know!
When I removed the old thermostat, there are six wires: yellow, red, blue, black, brown, and orange (but connected to a white wire).
Only the orange and yellow wires seem to be connected to the temperature control.
The other wires are connected to the fan speed and master on/off switches.
My new thermostat is also a Honeywell (model RTH7600D1014 - product link below). The back of the thermostat has a number of slots for wiring but none of the codes and the installation instructions make any sense! The install instructions assume you are replacing a 4-wire thermostat.
Thanks!
New Honeywell Thermostat:
http://www.homedepot.ca/webapp/wcs/s...k=P_PartNumber
Replacing old Honeywell thermostat with new Honeywell thermostat-img00336-20110331-2008.jpg   Replacing old Honeywell thermostat with new Honeywell thermostat-img00394-20110413-2206.jpg   Replacing old Honeywell thermostat with new Honeywell thermostat-img00395-20110413-2207.jpg
optimizer is offline   Reply With Quote
Old 04-14-2011, 10:47 AM   #2
Still Learning
See on your new thermostat there are letters on the terminals? On the old thermostat are there letters next to where the wires are? The reason i ask is because the wiring is different for gas heat, and heat pump. The new thermostat is compatable with both. Can you take a look at your furnace? What is the model number? Do you have cooling as well?
thehvacguy is offline   Reply With Quote
Old 04-14-2011, 10:50 AM   #3
Still Learning
We need to know what kind of system you have. The wiring is different between gas heat and heat pump, so we need to check the model number. Dont worry, your new thermostat is compatable with both. Can you see letters on the old thermostat where the wires are connected?
Old 04-14-2011, 10:52 AM   #4
Still Learning
Dam computer
Old 04-15-2011, 01:19 AM   #5
MXer
3 legged dog's Avatar
Looks like a line voltage chiller stat. You cant use a 24 volt stat.
here is a link.
http://s3.pexsupply.com/manuals/1253..._PROD_FILE.pdf
3 legged dog is offline   Reply With Quote
Old 04-17-2011, 05:54 PM   #6
Thanks for getting back to me! I put together the attached diagram to show the wiring and what the back of the old thermostat looks like. Not many of the wires are labelled but I also added labels for what the switches do.
In the bottom right corner in the square is the diagram that is illustrated on the back panel of the thermostat.
Sorry, not sure what kind of heat system my building has!!
Old 04-17-2011, 06:47 PM   #7
I initially tried uploading the wiring diagram as a PDF, but that didn't work. Here it is in JPG.
Replacing old Honeywell thermostat with new Honeywell thermostat-picture-1.jpg
Old 04-17-2011, 07:00 PM   #8
An old Tradesmen
Your current thermostat is a line voltage thermostat that is used to control a water valve and the fan motor.
The RTH thermostat you have is a low voltage thermostat, and can not be used on your system, without adding a relay system.
Old 04-17-2011, 07:11 PM   #9
I can return the new one I bought... Is there another model you could reccommend to me?
Old 04-17-2011, 07:27 PM   #10
An old Tradesmen
As far as I know. They don't make a line voltage thermostat that is programmable or digital for your application.
Old 04-18-2011, 08:56 AM   #11
Hi - would something like this work?
http://www.honeywell-thermostat.com/...hermostat.html
Old 04-18-2011, 06:29 PM   #12
An old Tradesmen
It can open the water valve for heating, and turn on the fan to one fixed fan speed. It can't control cooling though.
Old 04-20-2011, 12:17 PM   #13
You mentioned a relay option... is this something common / straightforward / recommended? How would I get more info on getting this done, and/or who would be the right tradesperson (electrician or hvac)?
Thx!!
Old 04-20-2011, 07:22 PM   #14
An old Tradesmen
HVAC would be the right person. its not something commonly done though. So you would need someone that is good with controls and control wiring.
Honeywell Prestige HD thermostat wiring 1H/1C + Humidification System TekGamer HVAC 0 07-10-2010 12:58 AM
Replacing Honeywell thermostat with another Honeywell flipz HVAC 4 02-06-2010 05:19 PM
Replacing my 6 wire Honeywell condo thermostat Ivan33 HVAC 8 11-29-2009 02:04 PM
Replacing an OLD Honeywell thermostat Parent HVAC 1 11-21-2009 09:47 PM
Wiring help - Honeywell Thermostat w/ Carrier Heat Pump Tom Williams HVAC 7 09-14-2008 08:40 AM
