-   -   Replacing old Honeywell thermostat with new Honeywell thermostat (http://www.diychatroom.com/f17/replacing-old-honeywell-thermostat-new-honeywell-thermostat-101475/)
optimizer 04-14-2011 09:42 AM
3 Attachment(s)
Hi,
Not sure if this is something a DIY'er should be attempting to do - I thought it would be more straightforward than it now seem!! Lol...
I live in a condo where we have the old Honeywell thermostat pictured below. I don't know much about our heating / cooling system, but I believe that the condo centrally controls whether the heat or AC is on - and that's really all I know!
When I removed the old thermostat, there are six wires: yellow, red, blue, black, brown, and orange (but connected to a white wire).
Only the orange and yellow wires seem to be connected to the temperature control.
The other wires are connected to the fan speed and master on/off switches.
My new thermostat is also a Honeywell (model RTH7600D1014 - product link below). The back of the thermostat has a number of slots for wiring but none of the codes and the installation instructions make any sense! The install instructions assume you are replacing a 4-wire thermostat.
Thanks!
New Honeywell Thermostat:
http://www.homedepot.ca/webapp/wcs/s...k=P_PartNumber
thehvacguy 04-14-2011 10:47 AM
See on your new thermostat there are letters on the terminals? On the old thermostat are there letters next to where the wires are? The reason i ask is because the wiring is different for gas heat, and heat pump. The new thermostat is compatable with both. Can you take a look at your furnace? What is the model number? Do you have cooling as well?
thehvacguy 04-14-2011 10:50 AM
We need to know what kind of system you have. The wiring is different between gas heat and heat pump, so we need to check the model number. Dont worry, your new thermostat is compatable with both. Can you see letters on the old thermostat where the wires are connected?
thehvacguy 04-14-2011 10:52 AM
Dam computer
3 legged dog 04-15-2011 01:19 AM
Looks like a line voltage chiller stat. You cant use a 24 volt stat.
here is a link.
http://s3.pexsupply.com/manuals/1253..._PROD_FILE.pdf
optimizer 04-17-2011 05:54 PM
Thanks for getting back to me! I put together the attached diagram to show the wiring and what the back of the old thermostat looks like. Not many of the wires are labelled but I also added labels for what the switches do.
In the bottom right corner in the square is the diagram that is illustrated on the back panel of the thermostat.
Sorry, not sure what kind of heat system my building has!!
optimizer 04-17-2011 06:47 PM
1 Attachment(s)
I initially tried uploading the wiring diagram as a PDF, but that didn't work. Here it is in JPG.
beenthere 04-17-2011 07:00 PM
Your current thermostat is a line voltage thermostat that is used to control a water valve and the fan motor.
The RTH thermostat you have is a low voltage thermostat, and can not be used on your system, without adding a relay system.
optimizer 04-17-2011 07:11 PM
I can return the new one I bought... Is there another model you could reccommend to me?
beenthere 04-17-2011 07:27 PM
As far as I know. They don't make a line voltage thermostat that is programmable or digital for your application.
optimizer 04-18-2011 08:56 AM
Hi - would something like this work?
http://www.honeywell-thermostat.com/...hermostat.html
beenthere 04-18-2011 06:29 PM
It can open the water valve for heating, and turn on the fan to one fixed fan speed. It can't control cooling though.
optimizer 04-20-2011 12:17 PM
You mentioned a relay option... is this something common / straightforward / recommended? How would I get more info on getting this done, and/or who would be the right tradesperson (electrician or hvac)?
Thx!!
beenthere 04-20-2011 07:22 PM
HVAC would be the right person. its not something commonly done though. So you would need someone that is good with controls and control wiring.
