Replacing Old Honeywell T8575B Thermostat With Radio Thermostat Wifi - Wiring Proble - HVAC - DIY Chatroom Home Improvement Forum
Old 01-17-2013, 04:18 PM   #1
Question
Replacing old Honeywell T8575B thermostat with Radio Thermostat Wifi - Wiring Proble
I decided to upgrade my old thermostat with the new wifi enabled Radio Thermostat but I ended up with three wires that I did not use.
OLD
https://customer.honeywell.com/en-US...ratureDownload
Replacing old Honeywell T8575B thermostat with Radio Thermostat Wifi - Wiring Proble-old.jpg
NEW
http://www.homewerksww.com/radiother...on-16apr10.pdf
Replacing old Honeywell T8575B thermostat with Radio Thermostat Wifi - Wiring Proble-new.jpg
This is how I connected the wires:
no /color /function /letter on new unit
(1) RED -> Power -> Rc/Rh
(2) BLACK -> Common -> C
(3) BLUE -> Heat -> B
(4) GREEN -> Cool -> O
(5) - - e m p t y - -
(6) ORANGE -> Fan Common -> [did not use]
(7) BROWN -> Fan low -> G
(8) YELLOW -> Fan Medium -> [did not use]
(9) WHITE -> Fan high -> [did not use]
I assume that the 'Fan Common' wire is no longer needed but I'd like to know how to connect the other two 'speed control' wires to the new unit? Any help would be much appreciated.
hsnpn is offline   Reply With Quote
Old 01-17-2013, 04:27 PM   #2
raylo32's Avatar
Rewards Points: 1,238
Can't help on the speed control but heat on the Radiothermostat (and most others) is not the Blue, it is W for single stage (or first stage of 2 stage units) and W2 for 2nd stage. And cool likewise is Y and Y2.
Live long and prosper.
raylo32 is offline   Reply With Quote
The Following User Says Thank You to raylo32 For This Useful Post:
hsnpn (01-21-2013)
Old 01-17-2013, 04:35 PM   #3
Is my current set up wrong? I can turn my heat on and it works.
Old 01-17-2013, 04:47 PM   #4
raylo32's Avatar
Here is a chart of standard thermostat wire colors. The pros will weigh in here before too long but it looks like you have house wires that are non-standard colors. It might also help folks if you specified what kind of heat (gas, elec, heat pump, boiler, forced air) and provide mfg and model.
http://www.dr-fix-it.com/ttt/10005.html
hsnpn (01-21-2013)
Old 01-17-2013, 04:52 PM   #5
I'll fix it right away. I live in a condo and my heat is electric. Let me find out about mfg and model. Thanks again.
Old 01-17-2013, 05:02 PM   #6
raylo32's Avatar
Be careful... match the new thermostat function to the wire that previously provided that function on the old 'stat regardless of color.
hsnpn (01-21-2013)
Old 01-17-2013, 06:13 PM   #7
Yes that list is very accurate on what the different terminals do, and the type of heating system would make a difference. Unless you have a heat pump you shouldn't be using O or B. Plus some of the functions you list don't make much sense. "Fan Common" won't connect to the stat and all the fan speeds you have listed aren't controlled by the thermostat.
The easiest thing to do at this point is go to your furnace & find where the low voltage wires hook in. Hopefully they'll hook to a board with the terminal designations on it. Those letters on the board should match the letters in your stat. Just write down every terminal in the furnace that has a wire to it & what color the wire is. Then go to your stat & make it match.
JScotty is offline   Reply With Quote
The Following User Says Thank You to JScotty For This Useful Post:
hsnpn (01-21-2013)
Old 01-21-2013, 10:28 AM   #8
I took O and B out and used Y1 and W1 instead. Thanks everyone for helping me out.
Old 01-21-2013, 12:24 PM   #9
I guess that worked? After seeing the pictures you posted I wouldn't have the slightest clue what those terminals all do. That is one funky stat. If I came across that in the field I'd have to track it back to the furnace to see where all those wires went. If you managed to make that work you did pretty well.
Old 01-21-2013, 12:53 PM   #10
HVAC Tech/Owner
Rewards Points: 604
I came across that brand last summer...what a piece of junk....Yes it had the internet features for a smart home, but if you bumped the tstat it blanked out. The HO put it in and was bringing the electric heat on along with the heatpump.....for no reason...
As posted above....you have to have tiny fingers to check the wires
Technow is offline   Reply With Quote
Old 01-21-2013, 01:21 PM   #11
It worked well after switching the wires. And the WiFi feature is great
Old 01-21-2013, 02:22 PM   #12
HVAC Tech/Owner
Rewards Points: 604
Wifi feature is also great on better stats.
Old 01-21-2013, 02:41 PM   #13
Now that we're at this subject, what WiFi thermostats would you recommend? Let's say under $200.
Old 01-21-2013, 03:05 PM   #14
HVAC Tech/Owner
Rewards Points: 604
You get what you pay for. If you wanted a cheap WIFI stat You definately got it.
Old 01-21-2013, 03:06 PM   #15
Don't have much experience with the WiFi stats so I can't say persobnally know these are good, but I've heard good things about Nest Thermostats. The first generation model looks to sell for right at $200, 2nd Gen is $250.
http://www.lowes.com/cd_nest+thermostat_1335274929_
Tags
thermostat installation , wifi , wiring
replacing old lenox thermostat with new RTHL3550 honeywell dtthunbird HVAC 2 05-06-2012 11:41 AM
Honeywell Thermostat Wiring Differences DavidHwang HVAC 16 01-28-2012 03:11 PM
Honeywell stat wiring w/ Trane furnace JaePee HVAC 7 01-18-2009 07:50 AM
Honeywell VisionPro Thermostat infoskr HVAC 32 12-17-2008 04:44 AM
Wiring help - Honeywell Thermostat w/ Carrier Heat Pump Tom Williams HVAC 7 09-14-2008 08:40 AM
