Replacing Lennox Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 12-11-2011, 01:15 PM   #1
Replacing Lennox furnace
Lennox G40UH-36A-070-02. Technician peeked in small rectangular hole under blower (flame sensor?) and said a ring was cracked - showed a faint black rim. Supposedly leaking CO. True? Does the entire furnace need replacing?
Macaboy is offline   Reply With Quote
Old 12-11-2011, 01:24 PM   #2
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
depends on how old the furnace is,most 80% furnaces have atleast a 20 year warranty on heat exchanger while many 90% furnaces are closer to 30 years.
if the furnace is close to being up on its warranty or is giving you other problems it might be time to send it down the road.
if you do replace it get estimates from a couple differant guys .
most warrantys will be about the same on new equipt,youre paying mostly for a name and a fleet of shiny vans.
although im definately not a fan of lennox,trane,carrier or bryant.
goodman makes a good product,just doesnt look as fancy as some of the others.
plummen is offline   Reply With Quote
The Following User Says Thank You to plummen For This Useful Post:
Macaboy (12-11-2011)
Old 12-11-2011, 01:54 PM   #3
Cracked rings are common on lennox although they rarely leak co it does have a20 year warranty on the heat eexchanger check the serial number the 3 and 4th digit is the year although the part is only covered not the labor could be costly I would look at replacing with a amana/goodman great warranty andthe heat exchanger is tube style and will rarely crack
heatycooly is offline   Reply With Quote
The Following 2 Users Say Thank You to heatycooly For This Useful Post:
Macaboy (12-11-2011), plummen (12-11-2011)
Old 12-11-2011, 03:12 PM   #4
Thank you for the detailed replies. I'll check into the Goodman.
Old 12-11-2011, 03:37 PM   #5
Hvac Pro
yuri's Avatar
Rewards Points: 1,756
get a Lennox tech to check it. the heat exchanger has turbulator rings pressed into it where the flames enter it AND they are sealed in with black RTV silicone which is PERFECTLY normal. sounds like somebody may be laying a load of BS on you. the other part of has NO rings even though it looks like it does. those are rolled in compression holes with no ring, same as in a boiler.
Old 12-11-2011, 03:44 PM   #6
Yuri that model does have rings and yes they do eject which forms a crack when it does I use the inspector camera on all h/e's andhave condemned a number of them
Natural Gas Cost For Furnace 1 Hour Run Time hammerlane HVAC 25 01-14-2015 02:13 PM
Possible Lennox Furnace ignitor problem Paulg1 HVAC 4 11-26-2010 04:38 PM
Lennox Furnace Model #: 90UGFA3-75-6 GauravJ Electrical 0 10-29-2010 06:52 PM
Need help with a Lennox Furnace KCDrew HVAC 1 12-09-2009 05:39 PM
1973 Lennox ES2 Furnace Noisy indygo HVAC 1 03-26-2006 07:43 PM
