Old 01-19-2009, 06:36 AM   #1
Question
Replacing Johnson Control with Honeywell RTH8500
Installing Honeywell RTH8500 to replace Johnson control T210hp-10
It should be simple, that's what they claim.....
The wire coming from the wall are labelled as follow:
R
O
Y1
C
X
W2
I used the wiring diagram from page 12 (Installation Guide) that says:
R connect to Rc & R leave metal jumper in place,
O to O/B
Y1 to Y
C to C
X to E
W2 to Aux
Power back heat pump and furnace, set time and temp, doesn't work!!!!
Actually, HeatPump works, but fan in the central furnace doesn't?
Thanks in advance... I leave computer on to heat up the house
Pierre M is offline   Reply With Quote
Old 01-19-2009, 07:27 AM   #2
biggles's Avatar
down on the air handler do you see a G terminal wired in.....and is it going up to the subbase.thats a heatpump but the "air handler" is just that, or is it a furnace with gas?does the old stat,and new stat both have FAN ON/AUTO on that subbase? does the subbases have a G terminal?
Old 01-19-2009, 09:14 AM   #3
Average Joe/ex-Navy IC3
gregzoll's Avatar
Also, did you make sure to set up the Thermostat for your unit, and not just hook it up and put in the batteries? There is a little more to do with the Honeywells, then just open the box and connect.
Old 01-19-2009, 11:08 AM   #4
FROM BIGGLES: down on the air handler do you see a G terminal wired in.....and is it going up to the subbase.thats a heatpump but the "air handler" is just that, or is it a furnace with gas?does the old stat,and new stat both have FAN ON/AUTO on that subbase? does the subbases have a G terminal?
I HAVE TO OPEN UP THE UNIT, I WILL CHECK AT LUNCH (12H35)
AND YES, GREGZOLL, I PROGRAMMED THE UNIT, AFTER FINDING HOW BY A LOT OF READING i.e. center bottom key.
WIL SEE LATER TODAY, TEMPERATURE IS AROUND -8C SO NOT TO WORRY NOW...
THANK YOU BOTH, I WILL KEEP CHATROOM POSTED1
Old 01-19-2009, 05:46 PM   #5
I spoke to my serviceman, I had to make appointment for annual PM,
he told me to make sure GREEN or X wire is connected to G on HONEYWELL. No charge!!!
And now it works perfect.
I will post complete programming later.
Thanks every one, happy heat...
configuration so far and it work:
fonction =>> setting
170=>>9
180=>>0
240=>>5
300=>>0
the rest is personnal ¤C, hour in 24h
That's it.
Thank's again for the support.
Old 01-19-2009, 06:11 PM   #6
biggles's Avatar
the only difference with the G/FAN is in cooling mode it calls in from the stat,and on a heat pump there might be a time delay when your heating thru the air handler.brands differ on that one.good luck up north there
help with installation of Honeywell RTH8500 thermostat dg xy HVAC 19 07-28-2009 01:25 PM
Honeywell IAQ thermostat and humidity control GhostBuster HVAC 14 12-19-2008 01:28 AM
Honeywell RTH8500 spare contacts? golfnut65 HVAC 8 11-21-2008 11:14 AM
Carrier Infinity Control VS Honeywell VisionPRO 8000 Theromostat super_man4471 HVAC 2 04-26-2007 03:27 PM
