Replacing Insulaton On 3/4" Line Outside - HVAC - DIY Chatroom Home Improvement Forum
Old 05-11-2010, 02:33 PM   #1
Rewards Points: 640
replacing insulaton on 3/4" line outside
What type of insulation is best used to replace the insulation on the 3/4" line coming from the AC compressor outside? the stuff I have now is showing wear and looks like its time to be redone... would the standard rubber like black tube stuff you can get at lowes be good enough? also whats the best way to keep it on? just zip ties? (thats all there is on what I have now...) thanks!
BlueBSH is offline   Reply With Quote
Old 05-11-2010, 08:10 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,100
Any good rubber insulation will work. The stuff the trade uses is called armaflex. Zip ties work and it is not critical it be airtight.
Old 05-14-2010, 10:02 AM   #3
Rewards Points: 640
Well last night went out and took off the insulation outside going to the compressor unit... wow was it deterated... it littearly crumbled when I started pulling it off... but the old insulation seemed a lot thinner... probably 1/4" thick... the new stuff is 1/2" thick.... any idea on what R-Value the insulation should be? the stuff I put on says on it R3.8 wasnt sure if that was enough or good enough.... but then anything is better then crumbling and full of holes insulation right?...
anyways some more questions...
I was reading where it says the "refrigerant lines (plural) should be insulated" now I obviously just replaced the insulation on the suction line outside... the suction line inside is insulated and in relatively good condition on the straight parts... but have some parts they over tightened with wire ties and the vibration make it eat through the stuff so that needs replaced (About 3 ft section of a 20 ft line...) but what about the other line? any reason to insulate it also? the book I have says it plural like both should be then talks about insulating the suction line which is done...
next question... it says insulate to the plenum, I have it running littearly until it is touching the coil box and the insulation is firm up against it on the suction line... there shouldnt be a reason to insulate the part inside the box is there? its about half a foot of line there
last question...
things I read say the suction line should be hot... when I touch it, it is VERY cold when the AC is running... why do they say it should be hot? the smaller line for me is very cold... this is not a heat pump... its just a forced air system with an AC compressor connected to the A coil...
Old 05-14-2010, 02:25 PM   #4
Hvac Pro
yuri's Avatar
1) r3.8 is the standard and good
2) both lines are not insulated, suction is because it sweats and we don't want it absorbing heat/losing cooling
3) insulated up to the plenum and no further
4)line should be cold and sweaty in an ac unit, can be hot on the heat cycle of a heat pump
Old 05-14-2010, 02:31 PM   #5
Rewards Points: 640
Thanks!
I guess I'm going to finish up replacing the broken parts inside tonight and say its done!
Need to run gas line to Tankless Water Heater. anonymouscuban Plumbing 2 04-16-2010 03:56 PM
Questions regarding AC coil condensate line lassiter1979 HVAC 1 03-14-2010 09:47 PM
Can a roof vent identify where my main sewer line exits the house? YerDugliness Plumbing 8 01-26-2010 05:13 PM
electric line and gas line couch potatoe Electrical 17 09-30-2008 11:43 PM
Replacing plumbing system kbsparky Plumbing 5 09-16-2008 10:41 PM
