Old 05-02-2012, 12:38 AM   #1
Replacing insulation inside blower compartment of Furnace
In the process of cleaning my return plenum and seailing it, I took out my blower to clean it. Everything was incredibly dirty. There is 1/4" insulation inside the blower compartment that needs to be replaced or just removed. The blower is right next to the heater, and further down the line is the A/C coils. THe unit is in a semi-conditioned space, so I'm not sure if condensation would be an issue if I left the insulation out. Any recomendations as to what kind of insulation I would put in there? It looks like it is just regular black 1/4 inch insulation glued to the sides, but I don't want to just put anything in there with it being next to the furnace.
zeek27 is offline   Reply With Quote
Old 05-02-2012, 05:32 AM   #2
An old Tradesmen
You can use duct wrap. I use spray glue to put it on.
blower problems with bryant furnace. blowerissue HVAC 4 03-14-2012 12:34 AM
Insulation around blower compartment ok? Ginny28 HVAC 1 01-05-2012 04:32 AM
furnace blower cover whistling BlueBSH HVAC 4 02-17-2011 04:09 PM
How much power does a small furnace blower use? Red Squirrel HVAC 10 07-31-2009 10:03 PM
Replacing My Furnace, few simple questions compression HVAC 10 02-03-2007 06:00 PM
