Replacing Hot Water Baseboard - HVAC - DIY Chatroom Home Improvement Forum
Old 05-22-2010, 02:17 PM   #1
Is it possible to replace an existing hot water baseboard system with a hot water radiant floor system? Would this be made easier because the pipe is already existing? I am purchasing a home next month in the Northeast and am curious as to future renovation possibilities. The current flooring is hardwood with tile in the kitchen and bathroom. Any tips/advice would be greatly appreciated.
Thank You.
MrBobC is offline   Reply With Quote
Old 05-22-2010, 10:55 PM   #2
An old Tradesmen
Rewards Points: 6,124
Can't use the piping that goes to the baseboard in most cases. So it doesn't make it easier.
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
water pouring into basement from around water supply line matty8199 Building & Construction 29 12-29-2009 06:07 PM
Replacing pipe leading to baseboard radiators Donbee HVAC 1 03-05-2009 03:40 PM
Removing hot water baseboard heaters. Sandy1000 HVAC 4 11-02-2008 05:41 AM
Air in hot water baseboard - help! heydobbs HVAC 6 12-08-2006 06:08 PM
