Replacing Home Made Whole House Fan Blower - HVAC - DIY Chatroom Home Improvement Forum
Old 06-21-2009, 07:25 PM   #1
Mike K
Rewards Points: 83
Replacing home made whole house fan blower
I built a whole house fan system using a old squirrel cage blower from the original 100000 btu furnace after replacing it with a 75000 carrier Infinity furnace. I'm guessing the old blower I used is around 1600 to 2000 cfm? I installed a 18" hart and cooley diffuser With 24" of 18" pipe above it. Then used 18" insulated flex duct to route the air to the blower mounted in a 16ga steel box.
After checking the amp draw on my old blower I see its pulling 6 amps and it's the wrong static pressure. I would like to replace the old blower with something like this.
http://www.atrendyhome.com/qcwhhofan...hannelid=FROOG
Since I have the grill and flex already installed all I need would be a fan and damper set up. Can anyone recommend where I could buy one? Or what specifications I should look for? My home living space is 1500 sq feet.
rebar is offline   Reply With Quote
Old 06-21-2009, 07:53 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
Replace thermostat with a recirc feature...Cheaper and more than likely more easy.
Old 06-21-2009, 10:47 PM   #3
Mike K
Rewards Points: 83
I think you misunderstood me. This blower pulls air from the ceiling of my living area and push's it into my attic during cool nights. But needs to have a closed damper when its off.
Old 06-22-2009, 06:22 AM   #4
An old Tradesmen
Rewards Points: 6,098
What do you mean by, "its the wrong static"?
Old 06-23-2009, 12:21 AM   #5
Mike K
Rewards Points: 83
The furnace blower is designed for a home duct system but Im not sure on the SP. I restricted the discharge to "make" it work but its not ideal. It was just free..
The Quiet Cool system has these specs..
Motor Voltage = 120V AC
Motor Amperage = 2.5 Amps
Power Consumption = 300 Watts
Motor Speed = 1560 RPM
Air Flow @ 0.1. SP = 2250 CFM
Old 06-23-2009, 07:39 AM   #6
An old Tradesmen
The dampers in teh pic of that link.
Will cause a higher static pressure then .1"
Probably, a 1/4HP blower motor is what your current set up needs.
Replacing rim joists in brick house sylverfoxx Building & Construction 5 05-06-2009 09:07 PM
Complete AC installation in Old Capitol Hill Row House jacko10 HVAC 0 09-18-2007 06:42 PM
Replacing Wood Panel 4'x8' Siding Chevmann99 General DIY Discussions 5 10-02-2005 08:43 PM
Cost of replacing old knob ant tube wiring in house bikerboy337 Electrical 3 03-26-2005 09:50 AM
A facelift for your home Grumpy Remodeling 0 07-07-2004 08:43 PM
