Old 04-19-2012, 10:37 PM   #1
Replacing furnace gas valve
I need to replace the gas valve on my Trane XR90. The valve is a 36G22 209. I found places to purchase this valve, but am having trouble finding which kit I need to convert it to LP. Can someone please tell me? I think I only need the spring. Also, I see this valve has an adjustable regulator. Will that need to be adjusted or is the factory setting fine? Will the regulator need to be adjusted after converting it to LP?
Instantlegend is offline   Reply With Quote
Old 04-19-2012, 10:44 PM   #2
Professional
You need to have a professional do this as the gas pressure will need set after conversion. Research 36G22-214, it replaces the one you posted and comes with the LP kit.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 04-20-2012, 12:26 AM   #3
Missouri Bound's Avatar
Buy the valve and take it to your local LP gas provider, that's what they do.
Do you want it your way or the right way?
Old 04-20-2012, 08:49 PM   #4
give this some thougth...its not a diy project..have a pro do it needs to be set for proper operation....incomming. pressure..and manifold. pressure.. I assume it already has orifices for LP?????
Replacing flush valve on one-peice Kohler Toilet griffin2000 Plumbing 5 11-27-2012 03:04 PM
Replacing a Pressure Relief Valve for a Boiler multiphrenic HVAC 18 11-30-2011 12:16 PM
Furnace gas valve for a fire pit CFECO HVAC 16 09-15-2011 06:33 PM
How to Adjust mixing valve on furnace? maxpower_454 Plumbing 2 10-08-2010 08:59 AM
Replacing water heater drainage valve darsunt Plumbing 2 10-08-2007 10:17 PM
