Replacing Furnace Cold Air Return - HVAC - DIY Chatroom Home Improvement Forum
Old 11-09-2011, 02:25 PM   #1
Replacing Furnace cold air return
I'm replacing a 2 1/2 ton horizontal flow furnace up in my attic. I'm going from a York to a Goodman with a B case. The old one has a 16 in. flex hose going into a rectanguler box that attached to the bottom of the furnace. Due to the different size cases the box will not come close to working. Can I take that box off an attach the flex duct directly to the bottom of the furnace or do I have to have a new box made. Thanks for the help.
Copter17 is offline   Reply With Quote
Old 11-09-2011, 03:07 PM   #2
no you don't need a new box, just a rectangular to round transition like this
http://acunitdirect.com/dev/16-ducts...round-duc.html
it's not ideal, you will lose some flow, a gradual transition is better.
bungalow_steve is offline   Reply With Quote
The Following User Says Thank You to bungalow_steve For This Useful Post:
Copter17 (11-10-2011)
Cold Air Return Question NEW-B HVAC 0 05-31-2011 09:47 AM
Oversized Furnace, Undersized Return Air vents and Low Heat Output.... ?? LabRat0116 HVAC 4 10-04-2010 08:53 PM
Cold air return questions ekulrenlig HVAC 19 10-09-2009 01:44 PM
Cold Air Return in an Old House DaleB HVAC 2 01-09-2009 10:20 AM
Gas Furnace - Burning smell at return blakemcginnis HVAC 4 01-26-2008 08:29 AM
