Replacing The Flame Sensor - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-02-2013, 06:19 PM   #16
yep. first reading/figuring out how and what could I do to identify the issue, only than I will make any attempts on the furnace!
diy50 is offline   Reply With Quote
Old 03-02-2013, 06:22 PM   #17
Rewards Points: 6,652
A flame sensor would be the first thing to look at, second would be that controller. Controllers go bad, and if you have had issues with surges, and lightening strikes in your area, they can mess with digital controllers like that.
Old 03-02-2013, 06:34 PM   #18
yes. that seems a good plan. I still need to figure out how to pull out the flame sensor from that assembly, it looks like there is some sort of nut I can roll off.. will give it a shot.
Old 03-02-2013, 08:45 PM   #19
Roofmaster
Rewards Points: 2,210
What is the purpose of the metal protrusion behind the flame sensor? Is is possible that it is heating up, expanding, and shorting out the flame sensor?
Just a thought.
It seems to me that your flame pattern should be shorter and much bluer than they are. Too much orange. Not enough oxygen?
Old 03-03-2013, 12:31 AM   #20
how
Rewards Points: 1,104
The flame is high and might be overfired.
Needs a manometer check of the manifold.
Check the pilot sensor for porcelin cracks.
An in series DCMA check between the flame sensor lead and the ignition module to see what's at fault with the pilot ignition.
But... are those really chunks of your refrectory lining laying below those photos of your burners? Have you put a light inside the burner compartment and looked up at it?
how is offline   Reply With Quote
Outdoor Motion Sensor troubles LCBoomer Electrical 2 12-01-2012 06:20 PM
Flame Sensor Rod pete0403 HVAC 14 12-26-2011 07:33 AM
how can i test flame sensor? Steve72 HVAC 4 02-08-2009 03:38 PM
False Flame Sensor emgvega HVAC 3 10-30-2008 11:00 AM
