Replacing Fan Motor On Condensor Unit - HVAC - DIY Chatroom Home Improvement Forum
Old 05-05-2011, 02:42 PM   #1
replacing fan motor on condensor unit
when i purchased a fan motor from an ac supply house i was informed that i would need to change the cap from a 5 to 7.5. I had just installed a new 45mfd cap which was already in the unit. do I need to install a second one? and if so how do i wire it in? The motor I took out was a single phase 1/3 hp 1075 rpm 208-230 volt. the new motor has all the same numbers except the fact that it requires 7.5 cap.
jackaroe is offline   Reply With Quote
Old 05-05-2011, 03:04 PM   #2
JJboy's Avatar
You need to install capacitor that the new motor requires.
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 05-05-2011, 03:10 PM   #3
is this in addition to the cap that i have? and how does the second cap get wired in?
Old 05-05-2011, 03:37 PM   #4
JJboy's Avatar
You do not need to use the old motor capacitor.
Old 05-05-2011, 06:27 PM   #5
Hvac Pro
yuri's Avatar
Rewards Points: 2,296
The 45 mfd cap you installed. Is it a dual cap. ie has 2 ratings like 45/5 mfd on it and 3 terminals. If so you need a 45/7.5 mfd dual cap.
Replacing water line for refrigerator seannymurrs Plumbing 13 04-09-2011 06:30 AM
Replacing Section of Feed Line When replacing kitchen faucet??? spyboy Plumbing 5 03-21-2011 02:57 PM
Replacing old galv irrigation pipe tns1 Plumbing 8 09-11-2010 04:08 PM
Replacing windows in a Bedford Stone home tim_the_toolman Building & Construction 6 12-02-2008 07:27 AM
