Replacing Fan Center - HVAC - DIY Chatroom Home Improvement Forum
Old 06-02-2009, 10:38 PM   #1
Replacing fan center
Hello,
I have an very old Magic Chef furnace and a Lennox air conditioner. When I turned the AC on, the system wouldn't turn on. I called an HVAC guy, and he said that the fan center shorted out due to an animal chewing on a wire coming from the AC unit. This was late last Friday, so he couldn't get the part and said he would come back Monday. Unfortunately, he has not showed up or called back. My question is, how hard would it be to replace it? It appears like it is just removing the old one and installing the new one, making sure the wires match up. My other question is how do I find out what fan center I can replace my old one with, since I'm certain the exact fan center is no longer being made? By the way, the Magic Chef model is G-83-100D2C3.5-5 and the Lennox is a HS18-411-6P if that helps in any way. Thanks in advance for any assistance!
irateb is offline   Reply With Quote
Old 06-03-2009, 09:42 AM   #2
An old Tradesmen
Rewards Points: 7,370
Its probably still made.
And if not. Supply houses should have cross reference book.
Old 06-03-2009, 07:48 PM   #3
Think I would let the tech do it. There is a chance of frying all your low voltage components with 110volts if you make one mistake.
i have found that even ordering that part by furnace model number (Magic Chef no longer made) or by individual part number it does not come wired or with the same colored leads as the original. As a result you could easily misplace a wire and burn other parts up.
A tech would know by the diagram on the fan center or by using a meter which wires to connect correctly if they were a different color
hvaclover is offline   Reply With Quote
Jacking up house, full length joists raised beam off of center colums. Suggestions? slowjo Building & Construction 9 09-16-2014 06:56 AM
Question about replacing load center in older house speedster1 Electrical 5 05-14-2009 07:55 AM
Replacing wood on 24" center trusses Novar Roofing/Siding 2 04-24-2009 07:24 PM
Moved ceiling light in bedroom to center, now trips breaker blthomas Electrical 18 01-24-2008 04:29 PM
Drilling into Center Beam leted_82 Building & Construction 2 03-06-2007 08:52 PM
