Replacing Duct Tape Used on HVAC Ducts
Hello,
I moved into a new house about a year ago that has an unfinished basement. Since the area is unfinished, I can see all the HVAC duct work and I noticed that standard duct tape was used to connect some of the duct work together. I realize this is not the proper tape to use as over time it will not provide an adequate seal and I would like to replace it with the appropriate tape or mastic. I have a few questions about doing this: 1 - Most of the existing duct tape is still sticking fine. Can I just go over the top of it with mastic to seal the joints? Or, do I need to try and remove all the duct tape and then seal with the mastic and or metal tape? 2 - Is mastic enough to seal the joints or do I also need to use metal tape? If its best to use both, do you tape first and then apply mastic over the top or the other way around? I plan on finishing the basement in the near future so I'd like to get everything nice and sealed before I close it up! Thanks in advance for all the help. Paul |
Yes, do it....
Thanks for the response... but can someone help answer my specific questions?
Thanks! |
Then put a few extra screws into the joints to stiffen and support. Then coat everything with mastic. Two coats. |
Thanks for the input!
| All times are GMT -4. The time now is 09:32 AM. |
