Replacing Compressor Relay - HVAC - DIY Chatroom Home Improvement Forum
Old 05-10-2012, 09:47 AM   #1
replacing compressor relay
I need to replace a compressor relay for a small refrigeration system but unfortunately the part number was burned off when the thing fried. I was hoping to get some help in figuring out how to find a new one. The relay was made by MRKK, that's all I can make out. Here is a picture
And here is the information on the compressor:
NU-T131AME
100v
130w
50/60Hz
18.3/16.7A
HFC-134a
Any help is appreciated - thanks!
lee12 is offline   Reply With Quote
Old 05-10-2012, 07:38 PM   #2
An old Tradesmen
Rewards Points: 6,544
Go to the manufacturers website. they should have a listing of what potential relay and start cap to use.
Old 05-10-2012, 10:54 PM   #3
Rewards Points: 616
the relay in the picture is a current relay.... as beenthere says model # dictates relay....
carmon is offline   Reply With Quote
Old 05-11-2012, 07:52 AM   #4
Thanks for the responses. Unfortunately the manufacturer is no longer around and I have not been able to find a service manual for the instrument (this is for a bench-top refrigerated centrifuge so it's not as common as say a household refrigerator). I have also not been able to find any information about the compressor.
The few relays I have found on the internet that look like this are specified by horsepower (found one listed for 1/5hp and one for 1/6hp). From the information I gave on the compressor, is there a way for me to determine the hp? If I have to guess at one of these to try as a replacement, is it better to go with the higher hp? Any suggestions how I go about replacing this relay, given the information that I have?
Old 05-11-2012, 01:30 PM   #5
An old Tradesmen
How many BTU is the system. Convert that to HP.
The Following User Says Thank You to beenthere For This Useful Post:
ben's plumbing (05-11-2012)
Replacing Section of Feed Line When replacing kitchen faucet??? spyboy Plumbing 5 03-21-2011 03:57 PM
Homeowner needs advice re: replacing existing hardwired under cabinet lighting bombacho Electrical 4 02-27-2011 08:57 AM
Replacing old galv irrigation pipe tns1 Plumbing 8 09-11-2010 05:08 PM
Replacing Windows? Kyle Remodeling 13 12-17-2009 08:03 PM
Replacing windows in a Bedford Stone home tim_the_toolman Building & Construction 6 12-02-2008 08:27 AM
