I am replacing a Carrier 960 thermostat with a Honeywell 8500. Should be an easy install, but the wires are not matching up. Does anyone have experience with this wiring? We have a Bryant 2 heat/1 cool heat pump.
Thank you for the reply - I am sorry it took me SO long to post these photos. Again, if there is ANYTHING you can do to help it would be greatly appreciated!!!
The current connections to the Carrier thermostat are on the left.
The new Honeywell 8500 thermostat is on the right.
On the new t-stat you read the letters on the outside of the t-stat.
Yellow goes to y, orange goes to o/b, white goes to aux, green goes to g, red goes to R while keepin the jumper intalled between r and rc, and blue goes to C.
When programming make sure you pick the reversing valve energizes in cooling.
I installed a new Honeywell last fall, and had similar issues (wiring/colors/etc..) not matching with install diagrams. I called Honeywell, and their tech person walked me through to a successful install.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
