Replacing Bushings With Bearings On Blower Fan - HVAC - DIY Chatroom Home Improvement Forum
Old 08-29-2010, 04:07 PM   #1
replacing bushings with bearings on blower fan
Hi all, I just replaced the bushings on the blower fan of our old Maytag furnace with bearings. I did because the bushing on the drive side was shot (lots of loud chirping). Anyway when I turned the thermastat to cool & blower kicked on there is now a decent vibration, almost a whir. It's been running for about 7 hours and has gotten a little louder. Any thoughts on how to quiet the vibration?
Just an after thought. When I put the bearings in the cups that held the bushings they were slightly loose so I kind of jerry rigged the gap by cutting the lid to a plastic bottle top to make up the space on one side & on the other I used thin sheet metal because the gap was smaller.
Thanks for reading,
Jeff
bicidad is offline   Reply With Quote
Old 08-29-2010, 05:34 PM   #2
An old Tradesmen
Rewards Points: 6,824
Could be your spacers are moving.
Old 08-30-2010, 09:19 PM   #3
Thanks beenthere. My spacers did move but even when I tightened everything back up the whirring/vibration is still there right when the motor starts. Also today i pulled the squirrel cage out & cleaned the fan blades & each end of the wheel, put it all back in and the vibration is louder but at the same frequency. The fan spun freely & smooth by itself. But noticed when I was putting the belt back on that the motor, the drive shaft moved about a 1/2 inch. The motor was also almost too hot to touch when I disassembled everything after running a couple of hours.
I also read a few threads on other forums about the capacitor being bad? Should a unit 15 or so yrs. old have a soft start up? Cause our doesn't.
Thanks,
Jeff
Old 08-31-2010, 05:51 PM   #4
An old Tradesmen
Most residential belt drive blowers don't have, or need a capacitor.
Old 08-31-2010, 06:38 PM   #5
Hvac Pro
yuri's Avatar
Rewards Points: 1,756
Did you put roller bearings in? Make sure the whole bearing is not spinning in the holder/housing. The inner part of the bearing needs to be turning and not the whole bearing in its rubber sleeve or holder. Check it carefully with a bright flashlight with the belt on and running and not just spinning by hand. Can happen if the grease in the bearings is old and stiff from old stock bearings.Sounds like the motor is old and dying. Check the amperage draw of it and compare it to the rating plate.
Bryant Plus 90 - No Blower Ducaticorse HVAC 13 01-03-2015 04:39 PM
Replacing Fasco 7062-3136 draft inducer blower on my Bryant Gas Furnace thalweg76 HVAC 0 02-20-2010 03:35 PM
Carrier 58MXA Wiring Blower Switch 63012753 HVAC 0 10-06-2009 09:09 PM
Replacing home made whole house fan blower rebar HVAC 5 06-23-2009 06:39 AM
Replacing Inducer Blower allenzachary HVAC 8 12-28-2006 12:42 AM
