Replacing An Aprilaire Model 58 Humidistat With A Model 60 - HVAC - DIY Chatroom Home Improvement Forum
Old 01-25-2012, 06:55 PM   #1
Replacing an Aprilaire model 58 Humidistat with a model 60
Can someone explain the differences in the Wiring Terminals, they are not the same?
The 58 has a W/G Terminal and a C/F Terminal.
The 60 has a separate W Terminal, a separate G Terminal and a G/F Terminal.
Sino is offline   Reply With Quote
Old 01-25-2012, 07:09 PM   #2
HVAC Tech/ Browns Fan
W/G = heat and fan C/f = common and fan.
Tator1076 is offline   Reply With Quote
The Following User Says Thank You to Tator1076 For This Useful Post:
Sino (01-25-2012)
Old 01-25-2012, 07:10 PM   #3
Is that hum going to be hooked to furnace control board or using own transformer
Old 01-25-2012, 07:39 PM   #4
The original model 58 Humidistat is connected to the Furnace Control Board.
Compare Carrier Model 25HNA936A003 versus Model 25HPA636 gchapman General DIY Discussions 0 11-02-2010 12:52 PM
Aprilaire part 4851 Blower Activation Relay glassr HVAC 0 09-25-2009 03:57 PM
How to install Aprilaire transformer? Studly HVAC 9 09-18-2009 09:44 AM
Aprilaire 700a wiring issue bman2448 HVAC 1 12-29-2008 11:48 PM
Aprilaire 700 to Carrier product # FK4BNF003000AAA mag-md HVAC 10 12-17-2006 07:49 PM
