Replacing Ac Unit And Furnace - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-11-2013, 06:46 PM   #16
Rewards Points: 46
Originally Posted by beenthere View Post
Motor and capacitor at Graingers.
Take pics of wiring, and label where all wires go to before removing. Then you can take it with you.
I concur..If it's just a capacitor, you'll be spending less.
Visually check the capacitor to see if its bloating or if you have digital multimeter that reads MFD you can check it's value.
You can buy capacitors on Amazon as well. Here is the link: Packard 440 Volt Round Run Capacitor 50 MFD
tampaite is offline   Reply With Quote
Old 05-12-2013, 06:58 AM   #17
Rewards Points: 38
just a follow up on my last post.
On my house, the magic chef replacement, the replacement furnace and A coil where replaced in January. The techs came back in April to install the matching condenser, lines and charging. The most time consuming part of the job was fitting the plenums to the existing duct work. You only want to do that once.
Worked out great, two smaller bills rather than one large.
Make sure you have that furnace fully inspected.
CO is DEADLY
bernie
bernie963 is offline   Reply With Quote
Old 05-12-2013, 11:03 AM   #18
Ok guys. It was bugging me not doing anything in this situation. I went outside today and took the top off the ac unit. I had my sister in law turn it on while I was out there and I tried to start it with a stick. No such luck. I pulled the motor out as well as two bundled capacitors. I took pics so maybe you guys can help me out. If possible I would like to limp this through this spring/summer so that would give me time to budget for a new system. There were two capacitors bundled together and one by itself. The one by itself had no wires from the motor running to it. Here are the pics.
Replacing ac unit and furnace-image-2441470591.jpg   Replacing ac unit and furnace-image-592719187.jpg   Replacing ac unit and furnace-image-3935986596.jpg   Replacing ac unit and furnace-image-2631087515.jpg   Replacing ac unit and furnace-image-2545799343.jpg
Replacing ac unit and furnace-image-2979031679.jpg   Replacing ac unit and furnace-image-3123792970.jpg   Replacing ac unit and furnace-image-3127921760.jpg
blackws6ta is offline   Reply With Quote
Old 05-12-2013, 11:56 AM   #19
An old Tradesmen
Rewards Points: 7,372
Pics of a capacitor only tell us if its bad if its bulged out, or leaking badly.
Old 05-12-2013, 12:22 PM   #20
What?
Old 05-12-2013, 12:25 PM   #21
An old Tradesmen
Originally Posted by blackws6ta View Post
What?
Can't tell you anymore about your caps or motor then I could before.
Old 05-12-2013, 12:58 PM   #22
What's the other cap in the pic? Are the two caps i took off for the motor? I'm reading about start and run caps and then there is the third one in the pic that wasn't bundled together. Is that a cap for the compressor? Does the motor look like something that would be readily available? Same with the caps? I have a graingers ten minutes from my house. Is this something I can take to them and they can match up?
Old 05-12-2013, 01:06 PM   #23
An old Tradesmen
G E used a second run cap to give the compressor a small boost for starting. But it isn't an actual start cap.
Grainger should have the motor and all the caps.
Old 05-12-2013, 01:12 PM   #24
Appreciate the responses. I am going to try and get to graingers Tuesday. Appreciate the help. That third cap is nothing to worry about then?
Old 05-12-2013, 01:19 PM   #25
An old Tradesmen
It should be wired to the compressor. If it isn't, then someone sometime eliminated it, and put in a larger one for the compressor. So if its wired in, replace it, if not, no worry then.
Old 05-12-2013, 01:20 PM   #26
It is wired to the compressor.
Old 05-12-2013, 03:35 PM   #27
An old Tradesmen
They all look about the same age. You might want to replace them all for afety. However. Only the one that is used for the fan motor needs changed when you replace the fan motor.
Old 05-13-2013, 10:12 AM   #28
OP I went thru the same thing last year. I actually called 2 techs out to diagnose, they both did so incorrectly. I turned to the internet and with the help of these guys successfully pinpointed what the issue was.
I bought this multimeter with my 20% off, it will test capacitance among other things:
http://www.harborfreight.com/5-in-1-...ter-98674.html
Personally I hate parts swapping/guessing, caps are cheap but IMO it's always good to check the system and components out before you start just replacing stuff, unless it's an obvious failure like a bulging cap.
wheelsup is offline   Reply With Quote
Quote for new furnace. Reasonable? dengle HVAC 16 03-04-2012 07:01 AM
Electric Forced Air Furnace - Replacing AC unit w/ heat pump? burnt03 HVAC 2 09-18-2011 10:00 AM
Replacing 47 year old AC unit cable_data_guy HVAC 47 04-15-2009 03:01 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
Replacing My Furnace, few simple questions compression HVAC 10 02-03-2007 05:00 PM
