Replacing Ac Compressor Fan Motor F48k89a01 - HVAC - DIY Chatroom Home Improvement Forum
Old 09-21-2012, 02:43 PM   #1
Replacing Ac Compressor Fan motor f48k89a01
I have an AC unit with a ground floor outside compressor.
The AC is not working today, so I go to look.
60Amp breaker is not tripped. So I trip it for safe inspection of the compressor.
Fan on the compressor is not spinning. but is VERY hot, I can leave my hand on the top of the compressor unit where the fan is bolted in for about 2-3 seconds. I Pull the fan and top housing off and the motor spins freely but is VERY hot. I open up the hatch on the side and I find a small little device that is humming. I find a wire I can remove to stop the humming. (Pic attached)
I am assuming the fan is bad and needs to be replaced. Is my assumption correct, or is there something else i should be testing first?
Thanks for all who provide constructive assistance!
JWulf1092 is offline   Reply With Quote
Old 09-21-2012, 02:58 PM   #2
UPDATE: Directly after posting this, I went out, put everything back together, turned the breaker on, and viola, the compressor started with the fan spinning. So it appears the motor is not bad, possibly the capacitor? The smaller capacitor to the lower right, has been changed multiple times in the last 4 years I have had the system.
Old 09-21-2012, 04:08 PM   #3
as seen on tv
Rewards Points: 150
i would watch it it may go out on thermal again.
qbert is offline   Reply With Quote
Old 09-21-2012, 06:24 PM   #4
JJboy's Avatar
Check both capacitors the aluminum body
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 09-21-2012, 07:49 PM   #5
Qbert: It has not yet, but i will keep my eye on it. When you say go out on thermal, are you thinking that the motor is overheating and going out, or what???
JJboy: I don't have a way to check the capacitors. I was told expensive meter to properly do that...???
Old 09-21-2012, 08:09 PM   #6
JJboy's Avatar
Any meter with MFD feature.
Old 09-22-2012, 04:13 AM   #7
UPDATE:
This evening when i got home the motor was making a high pitched noise and not spinning and very hot again.
Pulled the breaker. At this point I am a half hour into the cool down, motor still very hot. Turned the breaker on for a moment, the compressor came on, but not the fan, immediately turned the breaker off.
JJboy: I do not have a meter with MFD feature.Should i just replace the small capacitor? That is the one on the lower right of the picture. It has been replaced multiple times in the 4 years I have had this house.
Old 09-22-2012, 08:09 AM   #8
An old Tradesmen
Rewards Points: 6,086
Try just replacing the capacitor, if it still over heats/stops running, then you probably need a new motor.
Old 09-22-2012, 11:13 AM   #9
Beemthere: Just the little small one correct? I am calling around now to find a comparable, or better quality replacement. It is a Saturday though...
Old 09-22-2012, 11:15 AM   #10
An old Tradesmen
Ya, the small one only.
Old 09-28-2012, 11:25 PM   #11
Ok, I replaced the capacitor. Got a used one from a client who is mgr for a large HVAC company in town. Same specs. Everything goes good for the last week, and now same issue. The but now the fan won't spin up at all. It will free spin no problem, and it looks like it wants to when I supply power as the fan moves an inch, and if I try to spin the blade while under power, it will move a half rotation or so, but then it stops. Once I kill the power the fan blade will freely spin again.
So I assume I need to replace the fan motor?
Replacing rotted sill plate in 120 yr old home M.dizzle Building & Construction 16 02-29-2012 03:53 PM
Replacing water line for refrigerator seannymurrs Plumbing 13 04-09-2011 07:30 AM
Replacing Section of Feed Line When replacing kitchen faucet??? spyboy Plumbing 5 03-21-2011 03:57 PM
Homeowner needs advice re: replacing existing hardwired under cabinet lighting bombacho Electrical 4 02-27-2011 08:57 AM
Replacing old galv irrigation pipe tns1 Plumbing 8 09-11-2010 05:08 PM
