| DIY Forum | DIY Blogs | Photos | Woodworking | Extreme How To | Advertise | Contact Us |
Previous Thread
Next Thread
More On This Topic
Learn how to remove side trim board to remove the siding on you house from a professional contractor in this free DIY home improvement video. Read More »
How to Heat an Ice Fishing House
by eHow.com
Ice fishing is a popular pastime in the northern states where the lakes and rivers freeze. The ice fishing houses range in sophistication from a little pup tent to a fully built, functioning home. There are several ways to heat the ice fishing house... Read More »
How to Change a Filter on a Furnace
by eHow.com
There are many types of furnaces and they all need their filters replaced periodically. Changing your furnace filter can be easy if you know where it is located or it can be downright frustrating if you can't find the thing. Read More »
How to Clean or Replace Furnace Filters
by James Drew
Allergy, air and furnace filters restrict more air and cause trouble in cooling and heating the home. Watch these tips from a professional home repairman, and learn how to clean or replace furnace filters correctly in this free video. Read More »
How to Clean or Replace a Furnace Filter
by Tim Gipson
Cleaning or replacing a furnace filter requires shutting off the HVAC unit, pulling out the clips that hold the old filter in place and inserting a high-efficiency filter, making sure it faces the right way. Replace a furnace filter every 90 days, or... Read More »
