Replacing 3 Wire Thermostat - Need Help! - HVAC - DIY Chatroom Home Improvement Forum
Old 02-16-2014, 08:49 PM   #1
Hello,
I'm replacing an old mercury thermostat from 1959 that has three wires:
Red - 4
White - 5
Green - 6 / Y
Only the green wire was connected to a letter/number, the rest were just attached to numbers. This thermostat is connected to a boiler only that heats the house using baseboard heater.
Honeywell Home/Bldg Center RTH2300B1012 5/2-Day Programmable Thermostat.
I've connected the red to the R that is joined with RC. The White to W. Green to Y.
The problem I'm having now is that the heater will not turn off - I've tried to set the heater to 70, but it is at 77 and climbing...
I went down to the boiler room and noticed that the zone control valve is open when it should be shut....
Anyone have experience with these old thermostats and what my wiring should be?
Thank you,
Banzzy
banzzy is offline   Reply With Quote
Old 02-16-2014, 10:06 PM   #2
* Couldn't find way to edit my original message *
Update - After a lot more googling, I found that the thermostat may not be compatible with the type of zone control valve I have. I have the White Rodgers 1311-102 box.
Does anyone know what type of cheap programmable thermostat I could buy that is compatible?
** Edit ** Would this work:
http://www.pexsupply.com/White-Rodge...zone-5274000-p
Old 02-17-2014, 12:58 AM   #3
Houston204's Avatar
Rewards Points: 556
http://www.emersonclimate.com/en-us/..._06_pg0298.pdf
http://s3.pexsupply.com/product_file...structions.pdf
Yes, that 1F80-0471 stat will work.
I'd verify that your stat number = color is the same a the valve number = color.
Valve number = new stat letter...
5 = R
6 = O/B
4 = W
Configure for hydronic 3 wire operation.
Houston204 is offline   Reply With Quote
The Following User Says Thank You to Houston204 For This Useful Post:
banzzy (02-17-2014)
Old 02-17-2014, 09:49 AM   #4
Thank you for the explanation!
Would it be worth trying to use the Honeywell thermostats that I have? It seems that I wired it incorrectly to begin with.
Old 02-17-2014, 06:11 PM   #5
Rewards Points: 150
re-read page 6 of the instruction guide. the number 2 warning
https://customer.honeywell.com/resou.../69-2327ES.pdf
hpyjack2013 is offline   Reply With Quote
Old 02-17-2014, 06:54 PM   #6
Rewards Points: 150
Do you need assistance?
We are here to help.
Call 1-800-468-1502
Old 02-17-2014, 08:05 PM   #7
AKA HVACTECHFW
Rewards Points: 1,208
The particular thermostat you are trying to use is not compatible with a 3 wire zone valve setup.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 02-17-2014, 09:31 PM   #8
Hello!
I wired the new thermostats like Houston204 mentioned and it is working fine so far!
Thank you for the help!
Tags
thermostat help , thermostat radiant heat
Installing Nest thermostat. Do not have C wire. Want to run new wire. SuddenlyPonies HVAC 10 05-08-2013 09:15 PM
blue wire on thermostat? Jmosely98 Electrical 2 04-09-2013 04:00 PM
I need help wiring my thermostat. batalbj1 HVAC 3 03-28-2013 10:30 PM
Honeywell vision pro, fan always on? and True Steam problem c5sb HVAC 6 06-19-2012 09:08 PM
Honeywell Prestige HD thermostat wiring 1H/1C + Humidification System TekGamer HVAC 0 07-09-2010 11:58 PM
