Replacing 10 Year System - HVAC - DIY Chatroom Home Improvement Forum
Old 09-01-2010, 06:43 PM   #1
Question
Replacing 10 year system
I have a two story house with a split gas system (10 SEER). The upstairs condensor unit went out and I need to replace it with a 13 SEER unit. The gas furnice is in excellent condition. Can I get by with replacing the evaporator, or should I replace the furnace also.
hytechdave is offline   Reply With Quote
Old 09-02-2010, 08:14 AM   #2
Rewards Points: 1,214
Pro ably if the heater is in good shape and it delivers the proper CFM.
You will probably have trouble with the coil it will be much larger than the old one, so break out the tools and shears to adapt the new one.
Don't forget to change the line set.
COLDIRON is offline   Reply With Quote
Old 09-02-2010, 05:47 PM   #3
An old Tradesmen
Rewards Points: 6,074
If just going to a 13 SEER A/C, you can keep your current furnace.
Which heatings system should I go with? keano016 HVAC 5 12-01-2009 03:53 PM
What should I do? Replacing heating system mynd66 HVAC 22 11-17-2009 05:30 AM
Size A/C system properly 70stang HVAC 1 03-26-2006 08:22 PM
Replace furnace, coil and duct system sps123 HVAC 2 01-07-2006 11:56 AM
