Old 08-09-2007, 05:23 AM   #1
Replacement Room Thermostat
Hi all.
I want to replace an old Honeywell T6060B, manual dial type room thermostat. It has three wires (live, neutral and therm I believe). Just wanted some advice on what would be a good manual dial replacement for this unit. I just want something that looks a little more modern and, most importantly, will be a simple like for like wiring reconnection.
Many thanks
Sark
Sark is offline   Reply With Quote
Old 08-18-2007, 12:44 PM   #2
I relace it with a round honeywell type which can be purchased at most stores such as Home Depot ,Lowes or plumbing supply.You will only need two wires I'm pretty sure the instructions will show you which two wires you need.
imported_harryo is offline   Reply With Quote
