Old 01-06-2007, 01:21 PM   #16
Replacement pipe for hot water heat?
Originally Posted by trollmastergeneral View Post
That would depend on how many loops you have .I would imagine that you only have one loop not multiple loops.
You're correct their is one loop. The one loop has what I'm going to refer to as sub-loops comming off of it (radiators that were added on).
As far as adding multible zones the house warms up pretty evenly and is comfortable.
The only thing I'm considering is makeing two loops, of rather one main loops and the kind of a sub-loop I described before for an attached apartment.. I'm contemplating installing a second boiler and that would make any future install easier. I'm hesitent to give him his own zone as I know he'll run the thermostat around 75 degrees and tack an extra $100 a month onto the gas bill
Tmb9862 is offline   Reply With Quote
Old 01-06-2007, 05:30 PM   #17
Yes you can do that.you would have a second zone.You know when I see a landlord paying for the heat it is usualy set at 80 deg.
trollmastergeneral is offline   Reply With Quote
Old 01-12-2007, 11:47 AM   #18
Did you solve the problem?
redline is offline   Reply With Quote
Old 01-12-2007, 04:31 PM   #19
I havn't done any work yet but I now know I can use 1-1/4 copper, so yes I suppose that problem is solved.
The work itself is going to wait for the summer. The pipes are 80 years old, if they want to start breaking in the walls when I touch them I want it to happen when I don't need the heat.
Thanks to everyone for the help.
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Rust Spot on Water Pipe (Cast Iron or Black Iron maybe?) markmaclean80 Plumbing 6 08-22-2007 09:20 PM
Leaky Steam Heat Pipe NJE HVAC 6 01-30-2007 09:26 PM
Steam heat vs Hot water heat helpless handyman HVAC 5 10-03-2006 09:57 PM
Water pipe selection??? DK75 Plumbing 5 06-06-2006 12:09 AM
