Replacement Part For Aire-flo Furnace? - HVAC - DIY Chatroom Home Improvement Forum
Old 09-13-2010, 09:13 AM   #1
Rewards Points: 640
replacement part for Aire-flo furnace?
Anyone know where I can get a replacement condensent drain box (the white box that all the condensate lines run into inside the furnance before it turns into a drain outside the furnace)... I need to move my line, and my current one was cemented with PVC cement to PVC pipe, which needs to be changed to the other side of the furnace, but I cant do that without replacing the box unfortinuatly with how they installed it.....
my furnance model is: AF92MPE125U5B
BlueBSH is offline   Reply With Quote
Old 09-13-2010, 05:45 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,454
Cozyparts.com. They sell Lennox parts and AireFlo is owned and distributed by Lennox. Or you can come to Winnipeg for the fall colors and I will get you one from my Lennox depot. It is called a condensate trap. Needs to be washed out once every 3 yrs or it gets sludge buildup and shuts down the furnace.
Old 09-13-2010, 06:09 PM   #3
Rewards Points: 640
thanks!
alright since you brought it up, how do I wash it out?
Old 09-13-2010, 06:14 PM   #4
Hvac Pro
yuri's Avatar
Remove it and flush bleach, Javex/Clorox and hot water thru it.
Old 09-13-2010, 06:58 PM   #5
Rewards Points: 640
alright next dumb question, how do I remove it if they cemented it in? I seriously dont know what they where thinking and it was installed by a lennox dealer... they even glued it down where the hex screws are
Old 09-13-2010, 07:00 PM   #6
Yuri
Do you know if the aireflow is like the lennox in that the condensate trap has to be on the same side of the furnace as the exhast pipe? Only one I've ever seen was a POS air handler.
Old 09-13-2010, 07:02 PM   #7
Hvac Pro
yuri's Avatar
Sawzall?
Old 09-13-2010, 07:02 PM   #8
Rewards Points: 640
Originally Posted by Marty S. View Post
Yuri
the model I have you can only put the trap on one side, there is only one cutout for it to fit into, but you can run the drain to the left or right, the exaust is on the same side as the trap
Old 09-13-2010, 07:05 PM   #9
Hvac Pro
yuri's Avatar
Lennox has a crossover drain kit for the G61 to switch the trap to the other side. If not the water returns down the exhaust pipe and fills the ventor in the off cycle. Not sure about the AireFlos. Don't see too many of them now that we sell mostly high end Lennox stuff. Going for SLP training Wed. Apparently the trap can be mounted remotely a foot or two away from the furnace on a wall. Check Davenet for the install manual.
Old 09-14-2010, 09:41 AM   #10
Rewards Points: 640
looks like the aire flow furnace I have requires the condensate trap to be on the same side as the exaust vent.....
to make things more fun for me, the installers glued the rubber tubes onto the trap and onto where they attach tried to take them off last night to get the trap out....... ugh....
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 06:42 PM
gas furnace replacement - Winnipeg wendl HVAC 3 11-03-2009 09:26 PM
Purchasing a replacement furnace fearless HVAC 15 07-24-2009 08:09 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
