Replacement Of Duct Work - HVAC - DIY Chatroom Home Improvement Forum
Old 04-27-2013, 08:29 AM   #1
Replacement of duct work
I have a mobilehome a double wide that has the ductboard runs under it. The issue is that the critters have got in and made a mess I'm looking to replace it with a main run down the center and branch off picking up two floor vents on each branch one other issue is towards the end of the run air flow falls off. What would be a good size to start the main run and what would be a good size for the branch off's. I know there are other factors involved but I'm trying to get a general idea of where to start.
nightriderrv is offline   Reply With Quote
Old 04-27-2013, 08:41 AM   #2
An old Tradesmen
Rewards Points: 6,914
No way to guess. Would need to know what size equipment you have(A/C and heat). And what size rooms are. Or you could end up with as poor of an air flow as you already have.
Old 04-27-2013, 09:14 AM   #3
I hear that I'll put some info together and post it.
Old 05-02-2013, 06:18 AM   #4
This is what is in now
A 3 ton unit outside w/ heat pump
Duct is the ductboard 16x8 runs about half way then drops down to 12 wide
Just a standard air handler inside with the electric heat strips
The house is 30 x 56
Old 05-02-2013, 07:53 PM   #5
An old Tradesmen
16x8 is almost ok for 2 tons.
24x8 would be better. Then the 12 changed to 18x8
How far down will basement duct work drop my ceiling? ctote HVAC 1 07-17-2011 08:57 PM
Duct work help jsmith929 HVAC 4 07-10-2011 03:15 PM
Duct Work in Basement Handyman001 HVAC 1 03-02-2009 09:17 PM
Duct work patch pvsorge HVAC 9 10-09-2008 11:33 AM
Modifying existing duct work Thurgee HVAC 3 04-05-2007 09:35 AM
