Replacement Compressor Needed For Old GE Rotolock - HVAC - DIY Chatroom Home Improvement Forum
Old 05-17-2007, 12:29 PM   #1
Send a message via Yahoo to alex977
replacement compressor needed for old GE rotolock
Hi I have an old GE system/compressor. The original diagnosis was "worn finger valves" and I believe the pressures confirm there isn't enough pressure differential: low side is around 120 lbs, high side is a little under 200 lbs. The rest of the system is old but fine with no leaks... the problem is I'm having a hard time finding a replacement compressor. Manuf is GE, model is 32JF1J. Does anyone know of a replacement compressor other than this: http://americanhvacparts.com/Merchan...Category_Code=
My understanding is that these (or all?) compressors aren't rebuilt anymore ($6 part causing a $1000 problem...) and only new ones are available. Is this the case?
Thanks...
alex977 is offline   Reply With Quote
Old 05-17-2007, 07:36 PM   #2
I understand that letting go can be difficult, but this is exstreme....
harleyrider is offline   Reply With Quote
Soffits/Fascia replacement - I need some pointers! mcan5276@bellsouth.net Carpentry 1 03-13-2007 10:18 AM
Replacement Inducer Blower caseywa HVAC 18 11-27-2006 03:42 PM
