Replacement Combustion Chamber Kit OK? - HVAC - DIY Chatroom Home Improvement Forum
Old 02-14-2009, 03:08 PM   #1
Replacement Combustion chamber kit OK?
I had a local oil service person come in to do the annual service on my 10 year old New Yorker AP.590 oil fired boiler and he said the combustion chamber walls were crumbling(he showed it to me). I plan to get quotes for boiler replacement, but I did see that a combustion chamber replacement kit can be bought. I would like to do that in order to allow myself time to select(and save up for) my next boiler. I also live in Maine, so my cellar isn't exactly easy to get to with the snowbanks and ice. I would have him or another local professional install it. Does that seem like reasonable path to take?
safety1st is offline   Reply With Quote
Old 02-14-2009, 04:04 PM   #2
An old Tradesmen
Rewards Points: 8,142
If the rest of the boiler is in good shape.
A new chamber is ok.
Old 02-14-2009, 09:28 PM   #3
Thanks for the input. I think it is otherwise OK, but I wouldn't mind looking at newer more efficient models. I assume the replacement chamber probably reduces the efficiency by some additional amount.
Old 02-14-2009, 10:23 PM   #4
An old Tradesmen
No.
No lost from the replacement chamber.
Old 02-16-2009, 12:45 PM   #5
AP.590 boiler
Any idea where to get information on this burner? I have one but need troubleshooting info in order to figure out what can be done to fix various things.
mitsteig is offline   Reply With Quote
Old 02-16-2009, 02:54 PM   #6
An old Tradesmen
Local distributor.
Old 02-19-2009, 05:09 AM   #7
I found this forum doing a google search and there was a link on this forum to the manual for the AP.590, but the link was broken. You could keep trying to google search.
Old 03-20-2009, 01:09 PM   #8
Any more information
I also have a system, oil furnace, that needs either the combustion chamber re-lined or replaced. It is an older system , International (Utica Boiler Works). There is no data plate from which to read a model number. How can I properly size a replacement chamber? Who can explain the steps to successfully re-lining a chamber?
Frank
nygman is offline   Reply With Quote
Old 03-20-2009, 02:03 PM   #9
I saw your reply, but I don't think I can help, hopefully one of the pros here can. I am not sure any one can help without some additonal info on the actual unit. A quick google search found their web site....I assume you already looked there for information(www.uticaboilers.com).
I ended up having to get a new oil boiler anyway. They showed up with the replacement chamber, but too much damage had already occured to the walls.
Old 02-28-2011, 08:37 PM   #10
Burnham V-33/Beckett AFG
celticpiping's Avatar
Rewards Points: 20
Send a message via Skype™ to celticpiping
Safety guy, hey I'm here in Maine too.
Wondering how you got along with yer chamber lining kit...thing?
Did you end up doing a replacement ?
I'm faced with the same situation..
Thanks much,
Rich
celticpiping is offline   Reply With Quote
Old 02-28-2011, 09:04 PM   #11
The failure of the first liner damaged the metals outer walls, so it wouldn't have been safe to use the replacement liner. We got a whole new system, a Buderus, not sure of the model number, since it has been a while.
Old 02-28-2011, 09:06 PM   #12
Rewards Points: 20
aww bummer!
ok, thanks much for the quick reply!
Old 02-28-2011, 09:12 PM   #13
The guy did find the kit and was going to install the replacement chamber when he saw the extensive damage to the external metal. If your internal chamber is just starting to fail, the kit may work for you. I am not a heating expert, so I can't say if it can be done so that it performs as well as the original, I would assume it would be close(if not actually better since the chamber is in better shape).
Old 02-28-2011, 09:14 PM   #14
Rewards Points: 20
gotcha.
R
Bathtub Spout Replacement cspirit Plumbing 4 03-18-2011 06:39 PM
Furnace combustion chamber replacement tripower HVAC 2 10-21-2008 06:39 PM
sill replacement or? watchtower7 Building & Construction 5 06-07-2008 03:50 PM
Furnace Combustion Chamber tripower HVAC 3 10-30-2007 04:56 PM
