Old 01-10-2011, 01:45 PM   #1
replacement for bryant cess410104 defrost board
I have a bryant unit that is freezing up. I have had the freon checked. I believe that the defrost board is shot The board is cess410104. The board I come up with as the replacement is an icm320c. Is this correct? Also what is the difference between the icm320c and the icm320? I can find plenty of 320's but not many 320c"s. Also, When it freezes like this it will run for hours without going into any defrost cycle. I will turn on the cold AC for about 10 min. to defrost the outside unit But under the right conditions it will freeze up again in 2 or 3 hours. But this should tell me that the reversing valve is working properly, right or wrong?
Thanks,
aalan
aalan is offline   Reply With Quote
Old 01-11-2011, 11:04 AM   #2
Cmon guys. I feel confident that there is someone out there that can help me out with this. Please!
Old 01-16-2011, 08:18 AM   #3
Anything would be helpful.
Old 01-16-2011, 08:32 AM   #4
An old Tradesmen
Look for a part number that starts with HK.
Don't know what the difference is between the 2 boards. have you or a tech checked to see if the defrost stat is working?
A bad defrost board will cause what you described.
The Following User Says Thank You to beenthere For This Useful Post:
aalan (01-16-2011)
Old 01-16-2011, 09:38 AM   #5
This is an older unit. There is no part # that starts with HK. This board was before those I believe. No I haven't checked the thermostat. I can replace the board and the stat myself for $65. Alot cheaper than having a tech come out. Really just wanted to make sure I was ordering the right parts.
But if I can turn on AC and defrost the unit, does that not tell me my reversing valve is working?
Old 01-16-2011, 09:42 AM   #6
An old Tradesmen
Yes, that indicates the RV works.
RV's themselves seldom fail.
aalan (01-16-2011)
Old 02-01-2011, 10:25 PM   #7
Replaced defrost board and thermostat(65$). I don't know about the board itself, but the thermostat was stuck OPEN, so it was never calling for a defrost cycle. Life is good again!
Thanks for everyones help!!!!
P.S.
The ICM320 and the ICM320c are the same board.
York gas heater control board replacement spyvan HVAC 5 12-29-2008 08:12 AM
Any experience with Dupont Real Touch elite laminate flooring? danidisney Flooring 12 08-24-2008 04:22 PM
replacement of plaster board abc Remodeling 2 03-28-2008 03:56 PM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 11:50 PM
Ruud a/c control board replacement ? kourso HVAC 1 07-20-2006 10:33 PM
