Replaced Thermostat And Now Blower Motor Will Not Run - HVAC - DIY Chatroom Home Improvement Forum
Old 11-07-2012, 07:52 AM   #1
Replaced Thermostat and now Blower Motor will not run
Greetings,
I replaced an original rheem 41-20804-15 thermostat for our rheem heat pump.
With a Honeywell RTHL3550D, the cooling worked fine. When I tried the heater, the blower ran for 2 minutes then shut off. I put the original thermostat back and now the blower still does not come on. The whole unit (blower and heat pump) are outside. I checked the fuses and that the unit is getting power. The squirrel cage for the blower turns freely and if i push in on the relay the heat pump fan kicks on.
Any suggestions?
thx,
Rocky
rokman is offline   Reply With Quote
The Following User Says Thank You to rokman For This Useful Post:
pleasehelpme? (11-08-2012)
Old 11-07-2012, 05:15 PM   #2
An old Tradesmen
Rewards Points: 7,816
May have blown a low voltage fuse, or burned out the transformer.
Old 11-07-2012, 06:12 PM   #3
Rewards Points: 582
did you turn off power to unit when you changed stat....sounds like you may have blown 3-5 amp fuse on board???ben sr
Old 11-07-2012, 06:36 PM   #4
powered off all the breakers
powered off all the breakers before replacing the thermostat
and
checked all fuses
Old 11-07-2012, 06:46 PM   #5
An old Tradesmen
Stat may be miswired.
Old 11-08-2012, 05:45 AM   #6
Put original thermostat back in, confirmed wiring is correct, stil no blower motor.
Old 11-08-2012, 05:12 PM   #7
An old Tradesmen
Check to see if the transformer is putting out 24 volts.
