-   -   Replaced Thermostat and now Blower Motor will not run (http://www.diychatroom.com/f17/replaced-thermostat-now-blower-motor-will-not-run-162457/)
rokman 11-07-2012 07:52 AM
Greetings,
I replaced an original rheem 41-20804-15 thermostat for our rheem heat pump.
With a Honeywell RTHL3550D, the cooling worked fine. When I tried the heater, the blower ran for 2 minutes then shut off. I put the original thermostat back and now the blower still does not come on. The whole unit (blower and heat pump) are outside. I checked the fuses and that the unit is getting power. The squirrel cage for the blower turns freely and if i push in on the relay the heat pump fan kicks on.
Any suggestions?
thx,
Rocky
beenthere 11-07-2012 05:15 PM
May have blown a low voltage fuse, or burned out the transformer.
ben's plumbing 11-07-2012 06:12 PM
did you turn off power to unit when you changed stat....sounds like you may have blown 3-5 amp fuse on board???ben sr
rokman 11-07-2012 06:36 PM
powered off all the breakers
powered off all the breakers before replacing the thermostat
and
checked all fuses
beenthere 11-07-2012 06:46 PM
Stat may be miswired.
rokman 11-08-2012 05:45 AM
Put original thermostat back in, confirmed wiring is correct, stil no blower motor.
beenthere 11-08-2012 05:12 PM
Check to see if the transformer is putting out 24 volts.
