Replaced Thermostat But Fan Will Not Shut Off - HVAC - DIY Chatroom Home Improvement Forum
Old 03-23-2011, 06:31 PM   #1
Question
Replaced thermostat but fan will not shut off
i have had problems with my fan not shutting off on my furnace(gas) so some one suggested i get a new thermostat. after replacing the thermostat the fan continues to run and i dont know what i should do next. any help would be appreciated. thanks
gtshorty8611 is offline   Reply With Quote
Old 03-23-2011, 06:58 PM   #2
how
Rewards Points: 1,102
How many wires are connected to your thermostat and / or it a wireless?
Age /Brand / model of the furnace would help. Does your thermostat have a manual fan switch. Does your furnace have an interior or external summer fan switch?
how is offline   Reply With Quote
Old 03-23-2011, 07:51 PM   #3
Would be helpful to know manufacturer and model of the furnace or at least approximately how old it is. There are a few things that will cause this problem.
Mr.C is offline   Reply With Quote
Old 03-23-2011, 08:01 PM   #4
Post
its approx 13 years old lennox model c23-31fc-1
Old 03-23-2011, 08:04 PM   #5
Post
had four wires connected r, y, g, and w also had a blue wire that was not connected to old thermostat that i looked up and said probably did not need for my furnace. do i need to try and connect blue? bc everything runs fine the fan just wont turn off. has a switch that you can turn the fan off on the furnace in the basement but u have to come down to turn it back on too.
Old 03-23-2011, 10:50 PM   #6
HVAC / Plumbing
probably a stuck fan control / relay
kenmac is offline   Reply With Quote
Old 03-23-2011, 11:39 PM   #7
well It could be a fan control relay,a time delay realy, or a combination fan control/temp limit control thats sticking. If I knew the type of furnace could help you out a little better!
1mastertech is offline   Reply With Quote
Old 03-24-2011, 01:58 AM   #8
how
When you turn off the switch in the basement that turns off your fan, does it also stop the furnace from operating, if so that switch is probably a kill switch for your furnace.
You could try temporarily disconnecting the two thermostat lines on your furnace that control the fan. (Y & G) If the fan then goes off (when the furnace is cool )then you may have some thermostat wire problems. Put any nails through a wall where the thermostat lines maybe running about the same time that the fan wouldn't shut off???
If the fan stays on with those two lines disconnected then on a 13 year old lennox you are probably looking at a stuck fan relay.
Old 03-24-2011, 02:33 AM   #9
Ok now maybe were getting somewhere.the switch your talking about could be a bypass to turn on the fan try that but you said you had to come back down in the basement to turn it back on.this is probably a service switch to turn the furnace off .turn it off and than turn the tstat on and see what happens.
Tags
continuously running , fan , hvac fan
Odd Thermostat "Fan On" issue TJ_in_IL HVAC 9 03-30-2010 10:05 PM
A/C not starting up, bad thermostat? gringo HVAC 8 01-31-2010 01:37 AM
Thermostat wiring jetmanaz HVAC 1 08-09-2009 08:13 PM
ac/furnace runs whatever thermostat settign donbohn HVAC 1 06-20-2009 06:42 AM
Oil Furnace - Swapping out to Programmable Thermostat slappy HVAC 2 12-05-2007 04:57 PM
