Replaced Control Board, Fan Still Will Not Shut Off - HVAC - DIY Chatroom Home Improvement Forum
Old 01-25-2012, 02:21 PM   #1
Hello,
I replaced the control board on my Lennox gas furnace with an OEM White-Rodgers D341122PO1. This was based on everything I have read that indicates this would solve the problem of the fan not shutting off regardless of thermostat setting. BUT....the fan still runs non-stop.
The LED is giving me the "single slow flash" indicating that there are no trouble conditions detected.
Does anyone have any ideas?
Stagehand is offline   Reply With Quote
Old 01-25-2012, 02:38 PM   #2
Check the G terminal to see if it is powered. You are looking for 24v.
Possible stat wire cold be shorted to power. Check the fan mtr wiring to make sure that it is not not hooked to a hot, unswitched power supply.
hvac5646 is offline   Reply With Quote
Old 01-25-2012, 02:45 PM   #3
biggles's Avatar
remove the stat off the wall.... still running? pull the G off the board in the furnace still running...? someting within the furnace or on the board.if it shuts off pulling the furnace G the drop from the stat is touching R...R to G is constant fan
Old 01-25-2012, 03:00 PM   #4
I will check the voltage.
Fan will shut off if I disconnect the thermostat wiring. I am wondering if the tstat wire has a drywall screw through it somewhere?
Could be the cause maybe?
Old 01-25-2012, 03:54 PM   #5
biggles's Avatar
if the stat is of the subbase,and you diconnected just the G wire into the furnace and it went off ....the stat drop is making fan running R to G.if your jammed for heat and have a spare wire..if not use the YELLOW/Y for now(no ac till the spring) flip it at both ends. tape the GREEN/G at both ends might have R/HOT touching
Bad control board? juddskee HVAC 12 12-24-2011 10:59 AM
Changing Control Board Questions -- HSI module and AC wire connection humdinger0102 HVAC 7 11-17-2011 01:16 AM
Universal furnace control board Davidj0717 HVAC 1 10-14-2009 06:37 PM
HELP!! NEW Control Board & Same Problem!! Steve72 HVAC 3 02-11-2009 03:48 PM
Ruud a/c control board replacement ? kourso HVAC 1 07-20-2006 10:33 PM
