Replaced Carrier T-stat Batt, Now It's Dead - HVAC - DIY Chatroom Home Improvement Forum
Old 12-05-2008, 07:27 PM   #1
replaced carrier T-stat batt, now it's dead
Just had to replaced the t-stat batteries on my carrier Heat pump installed about 6months ago. But now it's stuck on temp-hold. can't even get the fan to come on, and of course this happens on one the the few cold nights here in TX.
Service is coming in the morning, I'm just wondering if maybe it's something simple I'm missing.
SOTX567 is offline   Reply With Quote
Old 12-05-2008, 07:32 PM   #2
try turning the furnace off at the switch, pull the batteries and put them back in. Then turn the furnace back on.
hvaclover is offline   Reply With Quote
Old 12-05-2008, 07:38 PM   #3
Tried that, no go.
Old 12-05-2008, 07:41 PM   #4
Do you have a meter, Tex?
Old 12-05-2008, 07:42 PM   #5
Pics of stat and furnace would be very helpful if possible.
Old 12-05-2008, 07:48 PM   #6
It's a Carrier performance series heat pump, can't remember the exact model offhand.
http://www.residential.carrier.com/p...formance.shtml
And this tstat, or very close to it.
http://www.residential.carrier.com/p...nprogram.shtml
Old 12-05-2008, 07:57 PM   #7
Hang on for an HP guy Tex. Ain't got em up north here.
Old 12-05-2008, 08:15 PM   #8
It might be on "keypad Lockout" mode. See instruction manual and perform procedure.
pbservano is offline   Reply With Quote
Old 12-05-2008, 08:54 PM   #9
no lockout, but upon further troubleshooting it seems as though the tstat is working as it should. However when i change the temp to a point where it should come on it will sit for a minute or two then switch to aux heat. but nothing will ever come on, not even the fan.
Old 12-05-2008, 11:16 PM   #10
You might want to check for a blown low voltage fuse on the air handler circuit board. Should be a purple 3amp fuse or a orange 5amp fuse.
SKIP4661 is offline   Reply With Quote
Old 12-06-2008, 12:06 AM   #11
Checked that too, it looks good. Unless there is another fuse or reset switch I don't know about, I have no idea.
HELP! Carrier Weathermaker Infinity Not Working! MaxPierre HVAC 27 01-19-2009 07:30 PM
