Replaced Blower Wheel - Now Trane Heater Will Not Blow Hot Air - HVAC - DIY Chatroom Home Improvement Forum
Old 01-14-2011, 09:47 PM   #1
Replaced blower wheel - now Trane heater will not blow hot air
For some reason my heater will not blow hot air - even if I set it to Emergency heat. The blower will not come on unless I switch the thermostat to Run instead of Auto. What can it be?
Skiphorn is offline   Reply With Quote
Old 01-14-2011, 11:31 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
you might have left a wire off after changing the blower wheel. should have a heating and a cooling speed. when turning on fan to run instead of auto you are using cooling speed. recheck wiring
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Bryant Plus 90 - No Blower Ducaticorse HVAC 13 01-03-2015 05:39 PM
Trane XL80 blower motor part number? keverino HVAC 17 01-10-2012 10:01 AM
Pilot on Williams millivolt wall heater goes out every 8 to 16 hours wornways HVAC 30 06-22-2011 04:29 PM
Trane XV 90 shuts off burner and exaust blower zootjeff HVAC 0 12-02-2009 12:50 AM
comfortmaker rpj2 blower wheel problems nuclearjesus HVAC 3 11-22-2009 09:14 PM
