Replaced Blower Motor In 58MVP Now It Wont Shut Off - HVAC - DIY Chatroom Home Improvement Forum
Old 12-19-2008, 09:41 AM   #1
Replaced blower motor in 58MVP now it wont shut off
Hi,
I just replaced my blower motor it was a hd46ae120 GE ecm motor with the same motor but the only difference I see is the old control module said 2.0 and the new says 2.3 but the motor is the same. Why won't it shut off? Any advice would be appreciated. THANKS
robr1 is offline   Reply With Quote
Old 12-19-2008, 12:11 PM   #2
An old Tradesmen
Rewards Points: 6,962
Because its the wrong motor and module.
The 2.0 you had, is not controled by pulse width modulation, like the 2.3 you have wants.
Old 12-19-2008, 01:30 PM   #3
2.0 vs 2.3
Hi,
Thanks for the info, does the mvp's circuit board have anything to do with it? Would a new circuit board be able to use the pulse system?
Old 12-19-2008, 04:08 PM   #4
An old Tradesmen
A new board designed to control pulse width, yes.
But, you'd be better off, taking that motor back, and getting the correct one.
Old 12-19-2008, 06:21 PM   #5
Thank You!
Carrier 58MVP Blower Problem mickd HVAC 54 06-10-2016 03:27 PM
Blower will not shut off. lj4 HVAC 14 12-11-2011 02:16 AM
Newmac furnace blower won't shut off dsgreer HVAC 2 11-03-2008 01:23 PM
replaced furnace blower now breaker issue Kurr HVAC 5 01-25-2007 09:22 PM
