Replace Two Thermostats With One Wireless? - HVAC - DIY Chatroom Home Improvement Forum
Old 08-29-2011, 08:14 PM   #1
Replace two thermostats with one wireless?
Hi, New user here. My 2 floor condo in a 100 year old 2 family in he Boston area was remodeled about 7 years ago. At the time the developer installed central AC alongside the old gas / hot water furnace. The thermostat for the AC is on the second floor (converted attic). The thermostat for the furnace is on the main floor. I would like to control both units from the same thermostat on the main floor because (1) I would like to have the fan on the AC come on and off with the heat to help equalize the floors and also filter the air in the winter; and (2) I would like to have the AC thermostat on the main floor at night and move it upstairs during the day (in the summer). I don't want to have to pull any wires if I can avoid it. I currently set the fan to just run in the winter but I would like it to cycle with the heat.
Will any of the newer wireless thermostats control two units. I have been searching and reading the specs but I can't tell if any of them have this capability.
Seems like worst case I could put a wireless thermostat on the AC so I can move it but I would really like to do both.
Any advice?
workindad is offline   Reply With Quote
Old 08-30-2011, 06:11 AM   #2
AKA HVACTECHFW
Rewards Points: 1,208
none that I know of will do what you want unless you run wire from 1 unit to the other.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 08-30-2011, 07:23 PM   #3
An old Tradesmen
Rewards Points: 8,242
It can be done. Will require an isolation relay be added to control the boiler though.
Old 08-30-2011, 07:30 PM   #4
Rewards Points: 6,652
Something like this http://www.nextag.com/remote-control.../products-html would be more in line to what you are looking for. Or you could go with something like http://radiothermostat.com/ which can be controlled from a iphone, android phone, or 3rd party software on your computer.
Old 08-30-2011, 07:31 PM   #5
AKA HVACTECHFW
they would still have to run wire though, correct?
IT IS WHAT IT IS
Old 08-30-2011, 07:38 PM   #6
I think that going with something like the ventstar http://www.nextag.com/Venstar-Wirele...61/prices-html may be a better way to go for the other person. Con is, that they cost around $230.
Old 08-30-2011, 07:46 PM   #7
AKA HVACTECHFW
Originally Posted by workindad View Post
At the time the developer installed central AC alongside the old gas / hot water furnace. The thermostat for the AC is on the second floor (converted attic). The thermostat for the furnace is on the main floor. I would like to control both units from the same thermostat on the main floor because (1) I would like to have the fan on the AC come on and off with the heat to help equalize the floors and also filter the air in the winter; and (2) I would like to have the AC thermostat on the main floor at night and move it upstairs during the day (in the summer). I don't want to have to pull any wires if I can avoid it.?
are the units (a/c and boiler) right next to each other or on different floors?
IT IS WHAT IT IS
Old 08-30-2011, 08:57 PM   #8
Rewards Points: 85
*** How about two wireless thermostats? Then you control them with one computer, which becomes your "thermostat". The cheaper RTCA one sells under the "Filtrete" brand at the Home Depots for $99.
- JerryK
jerryk1234 is offline   Reply With Quote
Old 08-30-2011, 09:06 PM   #9
Jerry, I use the ct-50, and when I first got it, it took a bit of learning curve to stabilize it on my network, and get the 3rd party software Thermostat for Windows to also behave. After that, I have had no problems with mine running.
Old 08-31-2011, 04:29 AM   #10
An old Tradesmen
A wire from the EIM to the air handler and to the boiler would be needed.
Old 09-02-2011, 10:22 AM   #11
Different floors, opposite sides of the house.
Old 09-02-2011, 10:55 AM   #12
If you have a C wire at both locations, either the ct-50 wifi, or like something along the lines of the Ventstar that I linked to, would probably be along the line.
baseboard heater wireless thermostat hohadcr Electrical 4 08-05-2011 06:06 PM
Replace door sill = Need new door? NNJGUY Carpentry 23 09-01-2009 01:54 PM
wireless router problems JAVAMAN PC Repairs & Upgrades 11 12-20-2008 02:50 PM
Carrier 58 PAV-repair vs. replace cczkcb HVAC 8 09-25-2008 12:57 PM
How to replace wood support posts under main beam webjanet Building & Construction 1 09-07-2008 10:15 PM
