Old 12-12-2009, 10:50 PM   #1
Replace Trane Weathertron (Baystat 339) with Honeywell RTH2410
I just replaced my old Trane Weathertron (Baystat 339) mercury thermostat with a Honeywell RTH2410. Everything appears to be working fine, but I'm concerned about a few things... I had to tape off the Blue and Tan wires because there were no connections available on the new Honeywell. Also, the instructions told me to put both the Black (X2) and White wires into the Aux connector on the new Honeywell. I have a heat pump with auxillary electric heat.
Does that seem right? Should I have purchased a more expensive Honeywell thermostat where I would have separate connections for Black (X2) and White as well as somewhere to connect the Blue wire (instructions on more expensive Honeywell thermostats say to connect the Blue wire to "C").
Any thoughts? Here's the breakdown of which old wires I connected to the new Honeywell RTH2410 (old - new):
R - R
O - O/B
Y - Y
G - G
X2 - W/AUX (combined with W)
W - W/AUX (combined with X2)
B - Taped off and tucked back into wall
T - Taped off and tucked back in to wall
I appreciate any help / advice you may be able to provide.
ammiller2 is offline   Reply With Quote
Wiring a Honeywell ProVision TH8321U1006, upgrade from Weathertron Tstat drandersoninc HVAC 6 10-04-2009 04:20 PM
new honeywell rth6300b to replace very old honeywell thermostat Designman20 HVAC 2 05-06-2009 05:43 AM
Replace Honeywell with Totaline 26kick HVAC 12 11-29-2008 07:27 PM
Trane Heat Pump tstat replacement with Honeywell prog - wiring question sep23 HVAC 2 10-20-2006 10:10 PM
