Replace Secondary Limit Switches On Lennox 80MGF? - HVAC - DIY Chatroom Home Improvement Forum
Old 02-05-2010, 12:18 AM   #1
Replace secondary limit switches on Lennox 80MGF?
A bit of a story to set up my simple question...
My Lennox 80MGF furnace was failing to ignite. After troubleshooting with the help of the web, I figured out that it was providing a "Limit Switch Open" error code. I used a multimeter and determined the primary limit switch was closed (no voltage across the switch), so I figured it must be an issue with the secondary limit switch. I ran a jumper between the 24V hot and return terminals, and the furnace immediately began its ignition sequence. The good part is that it continued firing after I removed the jumper.
I recycled the thermostat and power to see if it was fixed for good, and while the ignition sequence started, it soon stopped and I got the same old error.
I then disassembled the blower assembly to take a look at the secondary limit switches. I figured maybe there was something mechanical I could wiggle. Turns out that they are pretty much immovable parts that look like temperature sensors.
Anyway, I reassembled my furnace, and it's now working perfectly! I feel like a genius, since I've never worked on a furnace before. But I also know that I didn't really do anything except wiggle some parts.
Here's my question: Should I just stop now and be happy? Or should I preemptively replace the limit switches?
dawg89 is offline   Reply With Quote
Old 02-05-2010, 06:31 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 398
Don't worry Be Happy. It probably was a loose connection with the molex/wiring harness that the wires from those limits attach too. (I do lots of Lennox units). You jiggled/wiggled and they seated properly. NEVER have a failure of those switches. If it ain't broke don't fix it.
Tags
lennox , limit switch
Help me ID these switches... jp2code Electrical 15 05-02-2015 08:52 PM
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 05:42 PM
move 2 switches new location, replace with 2 for new lights qchawkfan Electrical 3 01-24-2010 11:15 AM
Lennox 80MGF Board Burned out jay235 HVAC 4 12-08-2009 09:23 AM
Lennox Limit Switch / Watchguard Issue shaneali HVAC 4 02-13-2009 06:16 AM
