Old 11-26-2012, 06:59 PM   #1
Replace or repair?
We just has the furnace guy out to service our Tempstar high efficenty furnace. Turns out the heat exchanger has lost two eyelets and he is afraid that it may start cracking soon. He recommends we replace it soon. he said that a new Furnace or heat exchanger is in order. We were told a new heat exchanger was going to run $1800 or so. It was installed in 2001, made it through the flood in 2008. Guy said it was a well taken care of. I believe it's a 5ton unit for a 3600 sqft home to include the basement. This will also need a exhaust fan because it's leaking water. this is a gas furnace.
Is this something I can fix? Should I just pony up and get a new one? They carry American standard, carrier and ducane. We know we have to stay at the 90%+efficient or better.
Mr Smiley is offline   Reply With Quote
Old 11-26-2012, 07:17 PM   #2
Professional
Replace or repair?
$1800 is a lot for a heat exchanger that should be in part warranty.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 11-26-2012, 07:39 PM   #3
Replace or repair?
I would have expected it to be. They are calling Tempstar and will let me know what they say. But from looking at their site they only offer a 10 year warranty.
Old 11-26-2012, 08:04 PM   #4
Professional
Replace or repair?
probably on parts, but heat exchanger typically have a 20YR warranty.
IT IS WHAT IT IS
Old 11-26-2012, 08:20 PM   #5
Replace or repair?
Okay. Well hopefully well know tomorrow.
Old 11-26-2012, 08:27 PM   #6
Replace or repair?
tempstar 80% eff furnace= 20 yr heat exchanger warranty ..90% eff furnace life time warranty...ben sr
Old 11-26-2012, 08:30 PM   #7
Professional
Replace or repair?
http://icpindexing.toddsit.com/docum...0106101015.pdf
see page 2
IT IS WHAT IT IS
Old 11-26-2012, 08:42 PM   #8
Replace or repair?
That's awesome! So hopefully well know what they will want to install it. I am the second owner of this furnace so I fall in the 20 year category.
And this is a 92 ultra high efficient furnace.
Old 11-27-2012, 11:22 AM   #9
Replace or repair?
what does made it through the flood mean? flood voids the warranty
bungalow_steve is offline   Reply With Quote
Old 11-27-2012, 11:44 AM   #10
Replace or repair?
In 2008 the city was flooded. The basement I assume from what I'm told got 4 feet of clear water in it. The furnace was overhauled as I understand it.
Old 11-27-2012, 11:52 AM   #11
Replace or repair?
I believe steve is right...if it was flooded..warranty void...and it should have been replaced by insurance company.....not overhauled...ben sr..sorry I missed that on post..
Old 11-27-2012, 12:02 PM   #12
I'm Your Huckleberry
Replace or repair?
Replace.
Thanks.
Doc Holliday is offline   Reply With Quote
The Following User Says Thank You to Doc Holliday For This Useful Post:
imayearin (11-28-2012)
Old 11-27-2012, 12:32 PM   #13
Replace or repair?
ok, so the original warranty is void, but the repair work may have a warranty, usually only a year though, for flooded furnaces they replace everything mechanical or electrical that the water touched (if reputable), even if the parts work, because it's a fire hazard otherwise, you can't predict what future problems may result from a flooded component (safety shutoffs may not work) big liability problem
You also have to understand that original quote they gave you is mostly labor, which the original warranty doesn't cover anyway, for warranty work usually they tack on a service charge and may require other things be replaced too once they open her up
Old 11-27-2012, 01:50 PM   #14
Hvac Pro
Replace or repair?
$1800 sounds like that includes replacing the leaking exhaust fan? Don't know if you have sales tax etc but that may run $2000 with taxes and not worth spending IMO. LIkely has a Honeywell Smartvalve which is not exactly the best unit in the world if you get my drift. $2000 may be close to half the price of a new furnace which will have all new parts and a warranty and is better value for your $$ IMO.
Old 11-27-2012, 04:51 PM   #15
Replace or repair?
Well with the thought of a new furnace. The company sells American Standard, Ducane, and Carrier. What would be a good recommendation and what could I expect to pay? My house is 101 years old. 1200 sqft on each level for a total of 2400 sqft of living space. I know we need to stay above 90% efficient. There is no return from the second floor to the furnace.
Exterior wall/siding dryrot: repair or replace? ohman Building & Construction 18 11-12-2012 06:58 AM
Pro Advice: Repair or Replace Deck ledger board and joists? jdm001 General Discussion 12 09-05-2011 10:46 PM
Lots of damaged drywall - repair or replace? jdelisle Remodeling 25 04-04-2011 07:37 AM
water damage remove mold & repair or replace drywall homerepair1 Drywall & Plaster 2 02-22-2009 11:00 AM
Repair or replace baseboard? handbanana Painting 9 04-09-2007 07:40 AM
